Temparature displays
  • Temparature displays
    Hi There
    Has any one or does any one have knowledge on how to get the ambient temparature and perhaps internal cabin temparature displayed on the carputer screen as a seperate application ? or maybe even visible like the time in media car or media engine ?
    thanks for the response
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    have you tried the matrix orbital displays? it's an external serial/usb LCD it has temperature probes. www.matrixorbital.com. Plugs in pc then program it to display the temp with the help of the sensor. That's what i've done, didn't intergrate it with the mediacar / media engine interface.
    MG ZR CARPUTER (UNITED KINGDOM)
      Which model do you use? there are TONS on thier site.
      Cheap Laptop, great for Carputer!
        To get the temperature you can use this kit. It sends data to the serial port, and also gets power from there.
        http://www.electronics123.com/amazon/datasheet/k145.pdf
        Order on this page (CPS145 one sensor included)
        http://www.electronics123.com/amazon...gue/c3-3-2.htm
        Extra sensors (supports up to four per board)
        DS1820, order on same page.
        I have ordered it, but not yet installed/written software for it.
          Go here
          scroll down to
          "Use PC joystick port to measure temperature and light levels"
          StreetDeck.com Developer (I am Chuck)
          Get StreetDeck at http://www.streetdeck.com
          The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
            I've got the hardware that NewTechFool describes. I'm using it to run a weather station. I've got multiple sensors (one inside, one outside) daisy chained to a long piece of CAT5, works great! You can even get humidity and barometric pressure sensors. Hardware is relatively simple, and tmp ensors are cheap. (I think they're around $3 each).
            VIA EPIA M10000 | 7" Lilliput Touch VGA | PW70 | 256 Meg RAM | 20 Gig 2.5" drive
            Dual Battery with Optima Yellowtop | Hellroaring Battery Isolater
            ICOM 2720A| Delorme Earthmate GPS | Tiny Track APRS
            Survives Crank
              Motherboard Monitor
              Aura MR62 (F and R)
              My Current MP3s
              IamDefiler.com
                Matrix Orbital MX 212USB and the temp probe last item on this page. I've built it in where the original clock used to be ( centre of dashboard) looks absolutely gorgeous, displays mp3 artist/title for 10 seconds, temp for 5 secs, and clock for 20 secs. It carries on like this. It comes with the LCDC software and new plug-ins can be downloaded from net if needed ( e.g equalizer disp that works with winamp) It has a splash start up screen sayin my name etc) SORRY FOR THE LATE REPLY. WAS WATCHING THE A-TEAM!!! Also i bought it from http://www.kustompcs.co.uk/acatalog/...ay_Mounts.html
                  Well I got the temperature module I mentioned in my post above. It is almost depressing how simple it is. Solder in a few components/wires, hook it up to your serial port, start HyperTerminal, and out comes a stream of temperatures.
                  I am REALLY impressed with this kit.
