Laptop Install Help!!!
  • Laptop Install Help!!!
    Hi guys I have a Dell laptop and have had te idea to install in my car for years. Now financially it's in reach. I need some advice about how i will power the laptop. Don't want anything permanent because I use the laptop in my house. Also on cattft.com they have a lliput screen an a screen that resembles the xenarc screen. Is the one which looks like xenarc actually the same as a xenarc.
    I have purchased Infomap Navigator with a Haicom GPS mouse. Now all I need is an inverter (don't know which one) and a screen.
    Any suggestions/tips on what to use, problems I may come across, or compnents which i have missed or some general advice would be much appreciated.
    Thanks!!!!!!
    but ok..
    non permanent way to hack the power of a laptop is with a docking station. and even then it might not work as desired.
    if you use a laptop, mount it as one with a proper mount. so you dont have to buy the screen, input devices, cables...
    no the lilliput and xenarc are not the same, even if they look close enough.
    any inverter will technically work.
    Welcome, cdm.
    You last visited: 09-13-2006 at 02:42 AM
    Private Messages: Unread 0, Total 3.
    Wow.. how things have changed in 4 years. Gone are the days of mcgyver and datalux
      I Totally agree, if you want to use a laptop, find the docking station! it will save you tons of grief and make installation a snap!
      Should also be able to find a dc adaptor (usually called an Auto/Air adaptor) for the unit, so forget the invertor! Why go dc to ac back to dc
      search on eBay..should be able to find both items there
      2005 Ford Focus ST
        Get this for yer power. It worked for my dell inspiron 3200.
        http://www.hoct.com/audcporeadfo.html
        StreetDeck.com Developer (I am Chuck)
        Get StreetDeck at http://www.streetdeck.com
        The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
          i need a power adapter for my dell inpiron 2500.. i cant find one
            psst. I have a Dell Latitude CxII. this is the adapter I am using, which according the the manufacturer, will also work with your Inspiron 2500:
            product:
            http://www.targus.com/us/product_det...sp?sku=APD10US
            compatiability chart:
            http://www.targus.com/us/downloads/A...Compat0504.pdf
            "If it works this good why F with it?" -KMFDM "Intro"
            Strive for ethical wardriving: http://faq.wardrive.net/
            My CarCPUs: v1 - 2000 | v2 - 2004
            Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
              Just get any inverter with anywhere between 100 and 200 watts - this will be plenty to power a laptop. Then simply plug in the laptop in the inverter like you would plug it into your wall at home. To connect the laptop to your car's audio without gutting anything, the best way is to use a wired FM modulator.
              Search for those on eBay - you should be able to set it all up for less than $80 bucks, trust me.
              00 Saturn SL2, boosted @ 8 psi - CarDomain
              Newest install - my quickest ever
              My 2nd carputer - b4 I broke the touchscreen
              My very first carputer - voted the most ghetto
                product:
                i tried that, goddamn power thing in the back is too big.. cant fit that and the power from the ps/2 port in at the same time.
                  then move to the next model up. it has multiple adapters.
