Running cables
  • Running cables
    When I run my cables in my car, I shall have several USB cables, VGA cable, audio cable and power cables.
    I'm considerring running the power cables down one side of the car and the USB / VGA cables down the other side to minimise interferance. Is this really ncessary? Have anyone had any problems with interference to audio, video & USB when running next to the power cables?
    Andrew
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
    It is necessary. You will be happy if you do it that way. If not, then you will find yourself doing it over.
    ATVMS.com
      As long as you keep the power cables atleast a couple of inches away, you shouldn't have any probs. Obviously if you run then on different sides of the car, that would be better.
        I'd run the power on one side, the audio on the other, and data down the middle (if your car allows this easily).
          If your install is clean and you use quality cables, it should not be an issue.
          I have built two CarPCs and not run into an issue yet with crosstalk between cables. Besides which all of the cables in my merc run down a cable tray along the bottom of the door frame with no problems.
          Craig
          Audi S8 supercar
          Modded Xbox 400GB HD
          Rear 7" screen & navplus
          Toyota Hiace Van
          Shuttle PIII 866 256Mb 10GB OPUS powered
          MediaCar & Mappoint 2004
          Custom fit 7" TFT VGA TSK
            If you're running power down to an amp, and then speaker cable back up... ANYONE will recommend at least 18" between the power/audio. Most recommend opposite sides of the car.
            Just a PC set-up.. ~150watts... even then I'd recommend running them seperately.
              Banderon speaks the truth
              Georgia Area Meet Photos
