Which Motherboard / CPU
  • Which Motherboard / CPU
    Ok,
    I'm just about to order an EPIA MII motherboard (probably the 1GHz as I can't find any where that has the 1.2GHz (mini-itx excluded).
    My PSU is an OPUS 90W. I need:
    - Small size
    - Low power usage
    - Low heat / low sensitivity to heat
    - Good spec etc.
    - Good price
    So, please tell me what you think, and ASAP as I want to order this evening.
    Andrew
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
    Ok.... so let's try again. Which EPIA Motherboard should I get? Is the MII 10000 the best?
    06 Volvo XC90
      if you need CF and PCMCIA built in then yes MII is the best. If you don't need those things than a cheaper M 1ghz is the best.
      Hope that helps.
      Never be afraid to do something yourself. Remember - amateur built the Ark, professionals built the Titanic.
        That was my thinking, just wanted to get someone to tell me.. before I spent the $$$
        06 Volvo XC90
          Also for the same money you can go with athlon-M, a little more power requirements, but a lot more bang for the buck.
            Ok, but which motherboard? I have a 90W OPUS. Where can I get it?
            06 Volvo XC90
              Athlon XP-M is about 34 watt, motherboard with everything onboard is 30 watt +HDD +optical you may actually run into problems, so on second thought I retract my Athlon XP-M idea. If you want to risk it I would go with www.newegg.com.
                Ok, the EPIA MII it is then.
                06 Volvo XC90
