RAM + DVD/RW + FM/TV Tuner + Amplifier and other parts...
  • RAM + DVD/RW + FM/TV Tuner + Amplifier and other parts...
    i'm searching where to buy this components, i searched on forum and on internet, can u give me some suggestion?
    i'd prefer to buy all at same store....
    1) the smallest (in dimension) 1gb RAM DIMM 184 pin DDR200/266 SDRAM
    2) the fastest and smallest DVD/+RW/-RW slot in
    3) the smallest FM/TV tuner, doesn't matter if is USB or PCI
    other hard to find parts:
    4) the smallest 12V 5.1 DD Amplifier (from optical and/or coassial), or 3 12V amplifier 2 channels (from normal jack)
    5) PCI connector T (something that can put vertical PCI to horizontal: |_ ) or a PCI cable with a terminal female slot (so i can inserti pci card on the position that i need)
    6) IDE cable connector with terminal male slot (i need to put the IDE connector outside the case)
    7) USB cable connector with terminal slot (same as IDE connector, i need to put the USB connector outside the case)
    8) RJ45 Ethernet cable with slot (same as ide connector and usb connector)
    9) touchpad (like on notebook)
    10) the thinnest keyboard
    hope u can help me, thx a lot.
    I have no clue why you think you need 1gb of ram in a carputer, but if you so insist, I doubt they make the slim form factor 1gb sticks, but its possible.
    Check the sound forum, there are very few 12v DD amplifiers, so your choices are quite limited. Can't say I'm familiar with the sizes, but I doubt they are small. If you really want 5.1 sound but have space constraints, get a 5.1 soundcard, use the analog outputs to a 6 channel car amp.
    They exist, check mini-ITX.com and other type sites, or ebay.
    Ok, I don't know of anything along these lines existing. Odds are you will either have to just use one long cable, or make some type of male-male connector yourself. (And don't go thinking you can make a 3ft IDE cable, it won't work. 24" is about the max)
    This one is easy, your board should have USB headers on it. Just go buy one of the brackets they make that can attach on to those headers, and take the USB ports off the brackets and mount them where you need them. The only issue, the brackets tend to come with fairly short wires if you need the ports far from the headers, then just use a USB extention cord.
    Hopefully you have a crimper and know how to make your own ethernet cables. If you don't, find a friend who does, or go to your local mom & pop computer store (someplace willing to help you out), and have them make the cable for you. Put a standard RJ45 connector on one end, and then use the wall jack connector (from Radio Shack for example) on the other end.
      i want to play world of warcraft ....if doesn't exist i'll take a 512mb ram, some idea where to buy it?
      and u know, pls, where i can take a very small 6 analog amp?
      thx, i'll check it.
      no i need only to take the connector outside the case, just few inches. i don't want to do it myself, i'm not expert to knit
      i can do it, but on my mobo there is a conncetor for lan ethernet at the center of the mobo near cpu, so i need a female connector (like the connector of USB, IR or CDIN connector)
      thx for ur help, hope to have more suggestion where to find all this components.
        aren't a few people with 10 foot, 80 pin, ide cables i can't remember his name but i know he drives a sick WRX :-D
