mobo audio jack sloppy
  • mobo audio jack sloppy
    after too much twisting and what not, the audio out jack on my epia has gotten too the point where it won't make good, solid contact with the cable plug anymore. get alot of static from the connection, min/maxing with wiggling. the problem is definately at the jack.
    the audio in and mic jacks are much tighter.
    any way to fix the connection? i dont really see an easy way to get inside the audio module to bend anything. they dont by ANY chance (not likely) make drivers that reconfigure the output jacks? like turn the 'out' jack into the 'mic' jack and vice versa? that'd be the easiest.
