will not shutdown
  • will not shutdown
    the carputer, now will not shutdown, it looks like it is about to shutdown, and it says saving settings, and then says shutting down, but is just stuck there, if i disconnect the usb orinoce client, it works like a charm, what seems to be the problem, also on the client when it says shutting down. the link and power light are on steady
    are you using the winxp drivers or the orinoco drivers for that card. It's most likely a driver issue
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
      i think it is the orinoco, since xp wouldn't pick it up. is there any bettery drivers
