HELP! Changed bios setting now can't see screen!
  • HELP! Changed bios setting now can't see screen!
    Hi,
    I read a couple of posts on the net about changing the type of screen in the bios to LCD to improve performance, now I can't see the screen!
    Can some kind person tell me the exact keyboard steps to change it back to CRT + TV in the advanced chipset menu.
    Think i need:
    From bios, to advanced chipset features
    Then to the screen type
    Then to CRT + TV
    Escape then navigate to save bios and exit
    Can somone give me the steps for above?
    please! Im fooked if i can't do this
    Regards
    John
    Flash your bios. easy wat motherboard have you got? just look for the flash bios jumper and it will change everything to default. Make sure you remove the atx power connector before flashing
    MG ZR CARPUTER (UNITED KINGDOM)
      if you got an m10000 its located pci slot is "pci facing towards north ". on the left hand side of the battery. the red little jumper just remove it and connect the other pin wth the middle one by usind the red jumper for about 2 secs and replace everything to normal
        or pull the little battery out and boot your puter up. it will lose it's saved cmos/bios settings and will go back to defaults. then put it in, and boot again and tweak the settings again in the bios and then save them.
