deep cycle battery recommended?
  • deep cycle battery recommended?
    for carputer use, are deep cycle batteries recommened?
    i have some bottom of the barrel battery in there right now, yet to install carputer
    2004 G35 Coupe project
    Deep cycle batteries are intended to deliver steady current of a long period of time, and generally you run them down to or below tolerable performance level before recharging them.
    So if you were going to use one for your carputer, you should probably make (or buy) some sort of device that will allow the carputer to run off of it for so long, and then let it recharge.
    And I'm not the God of Batteries, so if anyone wants to add to this or correct anything I said... go ahead and help out
    Nic
      cheapest deep cycle batteries in UK are Deta Orbital from http://www.rthursby.co.uk/acatalog/deep_cycle.html IMHO, if the computer reboots during crank then use a tank circuit (search this forum) and if you plan to use the carputer for long periods of time without the engine running then use a split charge system and have a second battery so you can at least start your car when the main one dies.
      if you can't find time to do it right, when are you gonna find time to do it over.
        Popping in to recommend the Optima Yellow Top deep-cycle batteries. I have one as my car's starter battery and two for the auxilary battery bank system. Recharged via the car's alternator.
          Good grief you're running three batteries? Why? What kind of systems do you have hooked up that you need three batteries? Outside of just preference I've only seen a few cars that had added electrical components that needed two batteries. I'm interested to know what you have in your ride and why you didn't just upgrade your altenator before buying three batteries.
          To answer the original question deep cycle batteries are usually used for running electrical systems when a generator(altenator) isn't present. Basically meaning there mainly used for running electrical components with the car off. As stated above they're designed to run to a low charge and then can be charged back up without loss in performance. In most cases you usually would use the deep cycle as your second battery. Personally I'd say if you're only running one battery go with a optima red top starter battery, if you want to run two batteries go with whatever you're using now for starting the car and run the carputer off the optima yellow top.
          Georgia Area Meet Photos
            falconey,
            Power drills and table saws. Seriously speaking, the aux bank is primarily used (other than block parties) for camping which requires long extended times between recharges. It has nothing to do with the output of the alternator or anything. I use the aux bank for other things other than the CarPC. There's a Xantrex XPower 1750 Plus inverter hooked up to it.
              I sometimes watch one of those car shows on Spike TV and that guy constantly metions Optima yellow tops (Obviously gets paid for it)
              Theyre good though?
              As for a second battery....are there any guides or plans or anything?
              I have no idea even where to begin doing that
                aoLhaTer,
                What everyone recommended above is a good place to start. I guess the next question is how often you're going to run equipment when the vehicle is NOT moving (i.e. not charging your starter battery). Second question is, what kind of CarPC you're wanting to install to figure out power requirements. Once you've figured that out, you can see whether if you just need a new starter battery or want to setup an aux battery just for the CarPC.
                  Well, Id like to run the PC every now and then when the car is off
                  Supposedly, the 150W opus PSU I have has an auto shutoff feature so that when the battery level dips below 11v the computer shuts off
                  My system Im running is a VIA Epia M10000 Nehemiah with a desktop 5400rpm 60gb drive
                    You're pretty safe then if you want to run it off your starter battery then. Go with a deep-cycle just in case (e.g. Optima Yellow Top) or something similar.
                      if a second battery is used (e.g. yellow top) would an isolator be needed to prevent straining the alternator if both batteries are low?
                      gaphix.com
                      MSI KM4M MicroATX, Duron 1.6, 512 Micron 2700, WD 80 7200 8mb, Pioneer 120S, M-audio 7.1 pci, Targus USB 2.0 hub, 3com 11a/b/g pci, PNY FX5200 AGP 64mb, Lilliput 7"
                        would there be any drawback to using a deep cycle battery?
                          Where you live, no.
                            Except maybe price. These Optimas aren't cheap compared to others.
                              There's a price premium. eBay my friend. eBay. Costco carries the blue-top ones too for about $148 USD, at least in our area.
