Dual bettery isolator QUESTIION
  • Dual bettery isolator QUESTIION
    the wire to the second battery does it matter how long it is would it still charge right if the 2nd battery was in the trunk
    Keep it as short as possible. Heat/fire is your #1 enemy in running a hot-wire to the trunk. Depending on your alternator and how much you are going to discharge your aux battery, you might need anywhere from 0 gauge to 8 gauge power-wire. Put in a fuse between the output of the isolator to the second battery, within 6" of the isolator, and you should be okay.
    Hope this helps.
      thanks alot
        Actually I would go one step further. Fuse the secondary battery within a few inches also, so no matter if the main wire shorts, the batteries are both protected. Two fuses are cheaper than a fire any day!
        2005 Ford Focus ST
