Harddrive mounting idea..
  • Harddrive mounting idea..
    I have attached an image of my harddrive mounting idea to help reduce shock. Comments?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Looks creative, but something like that might be more risk to your hard drive than normal shock. Not sure though, but I think i a lot of people get by without shock protection.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
      Here's my idea...
      Laidback
      The ultimate CarPC - Wow!
        The springs will make the shock worse. However, replace the the springs with rubber or a dense foam then they would act as dampers to reduce shock and vibration.
          however you mount it, it cannot have a hard end of travel stop. Move the drive in all directions, if it hits a hard stop it's no good. The screws will slap around in the holes causing shock worse than the original acceleration.
          Chris Krug
          owner, turbine minivan
          http://www.youtube.com/krugtech
            Exactly what I did. Been fine for nearly 5 years.
              the slapping of the spring will depend on the spring rates of the springs
              If I use really stiff springs with rubber bumpers, there will be no "Slapping".
                That plate with the holes in it that heve the springs on either side- What happens when the screws start banging the sides of the holes? You can't make the holes too small or it will bind, so there will be play. I vote for the foam too.
                Chris Krug
                  u guys using foam dont worry about heat issues?
                    As long as you only use small rubber/foam pads and don't encase the drive there shouldn't be a problem. Encasing it in foam/rubber would kill the drive rather quickly.
                      You shouldn't need either foam or springs - just solidly mount the case and drive so they don't bounce around and as long as your car suspension is not rock hard then it will be fine.
                      Steve
                      RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
                      Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
                      Webmaster for the European Ford Scorpio Site
                        You could just get one of these.... http://www.siliconacoustics.com/novibes3.html
                          In my initial install I used little rubber grommets on the screws (screwed into the mounting holes on the bottom of the drive) and kept the screws reasonably loose so the rubber was holding the drive up. Worked fine.
                          Though in my new case, the drive sits in its own little removable caddy with no shock protection. No issues.
                          89 Celica, CarPC installed, 1st bday :)
                          http://www.fishy.net.nz/carpc/
                          • MediaEngine
                          • Epia V8000
                          • 80GB WD 7200RPM HD
                          • Xenarc 700TS
                          • SB Live
                          • Opus 90W
                          • CIMR100 remote
                          • Deluo serial GPS
                          • D-Link USB radio wired to power antenna
                            yeah its no problem really most drives can take shocks of a g or two already. Mount it securely and don't worry about it. If your loosely mounted then your more apt to a serious shock.
                              I donno about that one, it's made to dampen vibration, not provide shock protection/suspension.
                              My car has a hard *** ride, I'm mounting the hard drive on some foam, then I'm using an IDE cable that has the extra bar on top of the connector. I'm going to have the cables go to the drive with a nice gentile s curve in the cables so movement wont fatigue the wires. Just enough foam to take the edge off the vibration and bumps.
                              Chris Krug
