Easy head unit question, and PC to amp question.
  • Easy head unit question, and PC to amp question.
    There are 4 female RCA jacks on my head unit. One set says rear preout and the other says front output. Can I run both of these to seperate amps?
    For the next one. My new head unit doesn't have an aux input jack. I figured it might be able to run directly to the amps. Is this possible? Thanks.
    -Kev
    1) Yes
    2) yes, with an RCA Switch, but your volumes will be different when you switch sources
    Nothing yet.....
      do a search 4
      pioneer aux in hack
      i use it on my keh-p7900 and it works like a charm.
      My Setup
        I can mail you the pic with the pins
        peter3
        [email protected]
        PETER - THE NETHERLANDS - DEVENTER
        sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
