black line, and black w/ white stripe line...
  • black line, and black w/ white stripe line...
    from my lilliput egg...took it apart a while ago and now i can't remember which is the +12v and which is the ground. I'm splicing into the PSU of my M10000. Yellow wire is 12v+ and adjacent black wire is ground correct?!?!
    just need to know which is which of the black and the Black w/ white stripe cables.
    Black with white stripes = GND
    Black = +12V
      thank you!! and am i correct with yellow wire is 12V+ and adjacent black wire is the ground?
        Yes that is correct.
        Have fun!!!
          damn....well i tried that and the screen won't turn on...no red LED, nothing. I have the power for it connected to the PSU (yellow and ground) and i have the Lilliput connected to the computer via the UPS and the "plug" for the back.
          i wonder if i'm doing something wrong. My brain is fried and i can't remember if i'm doing everything correct.
            new development...when i plug the unit in with the wall AC adaptor it does turn on.
            When i was in my car i even tried hooking the LCD up to the 12v of the battery and the ground for my car (the same way i have my stereo hooked up). What could i be doing wrong?
              not to question you seth but are you sure it's 12v=black and ground=black w/ stipe.
                bro you desperately need a multimeter. reconnect the egg adapter to your molex and see if you get 12volts. also the egg could be fried.. right, right?
                Mine needs to be updated.
                  Wait a sec. Just don't apply power again!!!
                    Did you slice the cigarette lighter adaptor?
                      i'm actually not using the egg...i fried it. This is a continuation of my old thread
                      http://www.mp3car.com/vbulletin/show...ight=fried+egg
                      I am using the piece that comes from the egg and plugs into the LCD. I am not using a cig-adapter, i first used the computer (which didn't work) and then i tried the 12v+ from my stereo (still didn't work). Went inside and hooked it up to the wall unit and it works.
                        +12V=Black/w white stripe, GND = Blk...... at least on my egg.
                        MikeH
                          which would explain why i couldn't get mine to turn on....can anyone confirm this before i totally fry my lilliput?
                            I have my Lilliput on the bench at home powered from an ATX PSU. To do so I sliced the cigarrete lighter adaptor. I just checked (3 times) and you are right. It's the other way around. The funny thing is that the mains adaptor (at least mine) has it the way I originally told you!!!
                            Damn Lilliput!!!
                              okay cool, i'm gonna go check it out and see!!
