Look at this case
  • Look at this case
    I can't believe that I actually could see this TINY CASE! I wonder if there is anyone who has used this yet? It seems awesome. It is Casetronic Travla C134 and it is barely larger than a full size CD-ROM as it seems. I was reading that you need special 'low profile' DDR though.
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    dude, use I just did and found like 170 posts about that case, it's been around for a while.
    BTW I searched just for "c134", probably can narrow search a bit more, but just trying to make a point. Don't do like all n00bs and use the
    '96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
    '00 Jeep Wrangler - planning stage
    What can BROWN do for you?
      Well I have ed and ed until my thumbs flew off, and everything in these searches discussed integrating into home theater systems. Oh well, I will buy it and then attempt to play with it
      EPIA MII-12000
      Hitachi 60GB
      Carnetix P1260
        luckily you still have eight more fingers to some more...
        j/k, it's a great case to use for a carputer.
        1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
          Here I'll help.
          2004 4runner
            Mine is smaller.
              Originally posted by Rob Withey
              Mine is smaller.
              You should probably keep that fact to yourself.
              2004 4runner
                Size doesn't matter, it's what you do with it that counts.
                  Here is pretty muhc the same case
                  These cases are all over the place..even at frys electronics...called mini itx case...her is mine and it is brutally modifyed
                  DICE Los Angeles
                    Mine's gonna be half of that if I disconnect the PCMCIA slots
                    00 Saturn SL2, boosted @ 8 psi - CarDomain
                    Newest install - my quickest ever
                    My 2nd carputer - b4 I broke the touchscreen
                    My very first carputer - voted the most ghetto
