Travla C137 & OPUS & ITX P4
  • Travla C137 & OPUS & ITX P4
    OK, just built a new PC cos the ASUS pundit has stopped working and I was fed up of not being able to use my OPUS. The general idea was to get as much as possible in the C137 case including the OPUS. In fact the only thing I kept external was the media drive which I've put in a USB 2 caddy for easy removal and loading.
    I like a bit of grunt in my PC, so I used a mini-ITX P4 motherboard with a celeron 2.4 ghz and 512mb RAM. Using the low profile 40GB disk for booting and apps, I can get 2 PCI cards inside and the OPUS.
    Here are some pics...
    The OPUS nestling where the old 120W psu used to live, its not fitted in properly or wired up yet, but you can see there is plenty of room.
    I had to find a low profile 1U P4 cooler as nothing else would allow the CDROM drive to fit. A cooler wasn't supplied with the case of the motherboard, strange is it's quite specialist kit.
    The low profile drive allows the installation of 2 PCI cards, if you use a 1" drive then you lose a slot. I fitted a TV card for use with radiator for radio and TV input for rear view camera in the future, tested that and it works fine.
    Here you can see the two PCI cards installed. The dual PCI riser supplied is a very tight fit and tends to bend forwards pushing the 2 PCI cards out of position. A better riser was purchased, but it came with only one extender, so rendering it useless. I will chase up why I only got 1 for a dual card and swap back to it at a later date
    Now I needed +5V and +12V for the external USB drive, +5V for the USB hub and +12V for the serial GPS receiver. So I'm using the original power socket for the +5v to the hub, I've fitted a 4 pin connector to the motherboard plate to give me the +12V and +5V for the external USB2 drive and there is a very tiny power outlet next to the upper USB2 sockets for the +12V. You can also see where the OPUS power will be connected. These were fire wire ports that I don't need. No extra USB sockets were supplied, the board supports 6, 2 on the back and 4 on board. I found a USB2/firewire adaptor at the local fair for 3 and chopped it in half to give me the USB 2 ports I needed.
    I'm just about done, currently its being powered by an external ATX PSU. I will test it all in the car very soon.
    Craig
    Audi S8 supercar
    Modded Xbox 400GB HD
    Rear 7" screen & navplus
    Toyota Hiace Van
    Shuttle PIII 866 256Mb 10GB OPUS powered
    MediaCar & Mappoint 2004
    Custom fit 7" TFT VGA TSK
    Nice job! I have a P4-ITX as well and I've been searching for a good 1U cooler. I was concerned that a 1U cooler wouldn't be sufficient for cooling my Celeron 2.4GHz. Which cooler are you using and have you had any problems? I'm trying to decide between the Vantec CCK-7015 and the Dynatron DC1206BM-V
    1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
      The Celeron runs very cool, the cooler I have is a solid copper 3.0 ghz cooler.
      Coolermaster 1U P4 Heat Sink Fan upto 3GHz ECU-PUA1S-35
      http://www.scan.co.uk/Products/Produ...roductID=68372
      Craig
      Audi S8 supercar
      Toyota Hiace Van
        Sweet rig!
        2004 4runner
          Results of testing
          OK, some good news and some bad news.
          First the bad news, the OPUS could not successfully power up my rig with 2x 3.5HD and a slim line drive. I suspect the +12V was overloaded. I had to put a 200GB disk inside the C137 and remove the low profile 40GB disk and buffalo PCI wireless card :-(
          Since then, no problems with the config, I have an external USB2 buffalo wireless device and everything is now onboard media wise and OS. Makes life a bit tricky when it comes to upgrades and adding tracks, but so what, that's why I have 54mb wifi.
          Drove 200 miles last night, no issues, case was cool and PC performed flawlessly.
          Craig
          Audi S8 supercar
          Toyota Hiace Van
            Post some pics of finished install in the car.
            Renault Megane...the OEM look
              Does anyone know where I can get some amp power connectors? I don't like the ones on the Opus.
              Craig, could you post some pics of the bottom of the case (Can't seem to find any on the net).
              Thanks!
                Anyone...?!
                  Try www.partsexpress.com or http://www.mcmaster.com.
                  Try searching for "terminal strip"
                  -Rich
                  http://www.mybimmer.net
                    Thanks!
                    I'm chasing that thing to. Half my problem is solved. I found some panel conectors like the one used to connect speakers wires, witch I'm going to use for low power quick conectors ( acc, leds, push buttons, etc. ).
                    For power wires I searched for amp power connectors or maybe the ones used in sealed subs enclosures. But no luck
                    Brave
                    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
                    Status -->
                    Lilliput Installed (not indash yet..)
                    BraveCar 2.5
                      Craig, how's it performing?
                      More pics!
