keyboard/keypad failures
  • keyboard/keypad failures
    Hi All,
    I am wondering about the keypads/keyboards that are in use out there. I originally used a membrane keyboard that I hacked up to only use the keypad portion, and after about 3 months of summer, the keys stopped working. The rubber plungers inside got all mushy, and then the guides that the keys slide in swelled up and froze the keys. Then I bought a commercial keypad, and after about 1 month of August/September, only about 3 keys still work. I just exchanged it for a new one, and we will see how long this one lasts. I live in New Jersey, not Death Valley. Has anyone else had similar problems with membrane type of keyboards/keypads?
    Mike
    I'm working on a keypad that's from an old cordless phone.
    The keys sit on a printed pcb with all the proper connections... I think it'll be much more durable than a normal keypad and there's no membrane
    (the really cool thing is that it uses almost exactly the same common connections so I only need about 8 wires to connect to the Keyboard controller.)
    Also, you might want to find a way to make it easily removable. the heat in a car could easily breakdown rubber...
    Good luck,
    -Miles
    Near Completion: Intel P166 MMX, 32MB ram, 13GB Hard Drive, Keypad, 4x40 LCD. Sproggy MK2.6 ATX PSU. Win98SE with Winamp and Mark Zehnder Plugin. (Web-site: very soon)
      Hi Milesg,
      Thanks for responding to my post. I am an electronic engineer so I can read schematics and figure out wiring. I have the controller board from the keyboard that I hacked the keypad from, and I might just wire pushbutton switches to it and be done with it.
      Mike
        You can look at my not so pretty website...in there I show how I made a keyboard customized for my stuff.
        I am using regular switches rather than the keyboard keys...still in development stage (that means it looks like crap but works)
        current projects
          I used a project box from Radio Shack that has the membrane with it for my Keyboard Hack. I just needed #1-9 so I cut off the remaining 6 buttons that I wasn't using. It's nice and flat and is part of my center console now.
            I just used a standard laptop numeric keypad. Plugs into the PS2 port. Mine has worked fine for 2 years. I guess it's the dust in your area.
