cutting holes in plexiglass
  • cutting holes in plexiglass
    How have you guys cut small square and circle shaped holes through plexiglass? using a dremel?
    whenever i tried to cut a small square in the middle of the plexi i screw up and it breaks where its not supposed to =(
    so any tips?
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    I use a large drill bit to get it started then cut it with the Dremel. Too hard to do it with a plasic cutter. I found a thin engraving tool for the dremel and at high speed it cut through acrylic like butter (because of the friction and heat), it should work the same for plexiglass.
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
      A dremel on moderate speed is probably the best way to go. Use one of those thin wood cutting bits. Start out with a drill to make a pilot hole, and then use the dremel. Some type of metal template makes it easy to get a perfect square.
