Write protect the hard drive?
  • Write protect the hard drive?
    I'm not going to go into details as to why I would want to do this, but here's the deal.
    I really need to write-protect an external IDE drive.
    A software method would be ok. I 'd all over the place but could not find any solution.
    I heard that there is a special byte in the HDs boot sector that disables/enables write protection. I need to somehow switch it on.
    You guys know anything about that?
    Man, I solve one problem, another pups up.. my system is completely weird.
    You know, if I can't finish what I'm hoping to finish by the end of this week I will simply make a new carputer with modern components. Low-budget systems suck
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Hey Yuriy
    Just found this utility that says it can do what you want (haven't tested it my self)
    Hope this little sucker does th job
      Thanks! I'll give it a try.
      Do you have a website for this one?
        Nope, that didn't quite work
        I forgot to mention that the drive I want to write-protect is an external IDE one connected via PCMCIA.
          Sure! Link
          You can't write protect it on an ide interface and then put it on the usb enclosure?
            I guess I could. However, when I run it I just get a blank DOS screen for a fraction of a second and before it closes. No text, no nothing. Nowhere to choose which drive to write-protect. There is one more utility on the website that you gave me, however it will not work on partitions and my drive is partitioned (since I use FAT 32 and my drive is bigger than 32 GB).
            Thanks for your help though
              Here is another link for ya. Loads of interesting stuff in there.
                Thanks for your trouble Seth, I appreciate it
                But luckily I managed to find a workaround to my problem, so I don't need write protection anymore
                Finally I can pack my carputer back in the car, where it belongs.
                  np Yuriy
                  Have fun.
                    Get partition magic, this will allow you to write protect your drives
                    Check out my hopefully useful site...
                    www.hobbybotics.com
                    It's still under design but it is functional
                      Already have it - there is no such option there
