homebuilt XM receiver
  • homebuilt XM receiver
    Slightly OT, but I thought everyone would get a kick out of it anyways...
    A guy on the XM411.com forums built his own XM satellite radio receiver. He used the XM receiver from a XMPCR. He just added his own control front end hardware to it.
    http://www.xm411.com/phpbb/viewtopic.php?t=4202
    Lots of pictures.
    P.S. For the uninformed, the 2nd gen XM receiver chipset is completely contained within a small metal can. Al 2nd gen receivers use the same receiver module. The only thing you have to do to get it to work is provide +5v power and a antenna connection. The module uses a very simple serial control protocol which is well documented thanks to the XMPCR. It outputs audio in a plan PCM digital stream at 24-bit 44khz. The XMPCR PC controlled receiver is nothing but a XM receiver can with a Serial to USB converter attached!
    Anyone with a little bit of microcontroller experience could build their own XM receiver.
    thats kick ***!!
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
      Wow, that is certainly some cool stuff, but I am lost for the intent of it.... It looks like he took something the size of a CD case (the XMPCR) that costs $50 and turned it into something the size of a small Volkswagon and costs $2000.....
      But again the effort and design is very impressive
