noob question
  • noob question
    not sure if i am posting in the correct forum
    i've been using caputer for a while
    but stupid enough...i didn't think i could output the sound
    to my car speakers..instead i put a set of pc speakers in there
    i m new here...now i see MP3car.com...with alot of skillful
    ppl...and most of u actually hook up the sound to the speakers in the car
    may i know how u guys do that?
    Many ways to do it; here are a few:
    Run output of your soundcard to an auxiliary input on your head unit if it has one. If your head unit does not have an auxiliary input you can use an RF Modulator that plays through the FM station on your radio. Also, if you have a tape deck you could run the output of your sound card to one of those cd to tape converters. Those are relatively cheap methods of doing it. More expensive methods are running the audi output through a USB sound card straight to your amp (if you have one).
    Check out my hopefully useful site...
    www.hobbybotics.com
    It's still under design but it is functional
      A lot of guys here hook directly up from the PC output to the RCA inputs of an amplifier. It has been reported to give a "jaw-dropping" sound. Wish it dropped a couple of other things....
      o/______\o
      (oo_OO_oo)
      []o-----------o[]
      '94 320i
        i have the same question...so what if i don't have a head unit [i'm replacing it with the lilliput], and i don't have an amp?
        don't let a day go by without finding some wonder in it...
          you will need either a HU or an amp
          AMD XP 2000+ 512Mb Ram MB:A-7VM400AM-RZ
          Zenarc 700TSV Netgear USB WiFi GPS Opus 150
          Running Win XP, FP, MM
            [cry cry] what sort of amp will i need? i have a 55amp alternator, plus i'll be running a computer...and lilliput
              Take a look into Ebay, there are a lot of cheap car amps for sale. If you go mega power, then you may want to get a CAP to get that extra juice when you need it.
              You'll need to get a phono to RCA connectors to connect your PC to your amp. Then use Windows Media Player or Winamp to control your volume. Good luck..
              http://www.crutchfield.com/S-u8RZ2OV...&avf=N&search=
              This looks like a good amp...
              o/______\o
              (oo_OO_oo)
              []o-----------o[]
              '94 320i
                i just want a little amp, i'm not a sound freak...[not that i have anything against them...] i just want to hear the audio created by my comp
                my question was asking more along the lines 'what type of amp should i get?' not 'where?'
                thanks a lot though
                  The reason you hear audio out of your computer is because the speakers you plug into the back of them are powered. The audio signal is uselss unless it is amplified, whether it's from a HU, ampifier, or computer speakers.
                  My Carputer! (More Car Pics at the end)
                  2 Kicker Comp 10"
                  Epia M-9000, 256 MB DDR, 120 Gig HD
                  Lilliput 7" VGA Touchscreen
                  Check it out?!
                    i knew that, i was just thinking i could use the same source my head unit did
                    hey euro, thanks for that link...even though that amp is a little stronger than my alternator [i believe]...i found a little wizard on the site that determines what is right for my vehicle...
                    thanks!
                      From now on take the blue pill and there's no turning back...............
                      o/______\o
                      (oo_OO_oo)
                      []o-----------o[]
                      '94 320i
                        hey saikano
                        are you still using your stock speakers?
                        do you plan on upgrading them?
                        how many speakers do you have?
                        A 55 amp alternator is not a "bad" as you may think. If you are lucky enough to find a 20x4RMS amp (assuming you have 4 speakers) it really wouldn't draw as much current as you think, no more than your computer really. And 24RMS is more than ehough power to push your stock speakers, probably 2x as much.
                        If you plan on upgrading your speakers you have more options, such as getting a 2 channel 100watt amp such as the one found here
                        http://cgi.ebay.com/ws/eBayISAPI.dll...710974044&rd=1
                        and then purchasing 2ohm stable speakers and wiring them in parallel to the amp, assuming the amp is 2ohm stable as well.
                        There are several options for you though.
                        I have heard of, but have never personally seen, an amp that pushes only 15watts per channel @4ohms, which would be perfect for pushing stock speakers.
