External Hard Drives
  • External Hard Drives
    Not too long ago some one asked if any one used an external Hard Drive. I would like to but can't seem to get my computer to recognize my external drive. I bought a External 80GB HDD from dealsonic.com and when I connect the computer says the device is workin and all but I don't see an Icon under
    "My Computer" and cannot access the 500+ files on the HDD now, or put anything on it. Does anyone know what I'm doing wrong? By the way the OS is win98
    Aut cum scuto, aut in scuto
    did you load the drivers?
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
      Yep
        - Configuration Panel
        - Administrative Tools
        - Computer Managment
        - Under 'Storage' select 'Disk Managment'
        - Right Click on the drive you see that is not showed in explorer, and then you hve options to get your HD running. (I don't know exactly how these options are named)
        gl
        Needstorage
        Who the hell is general failure?!?
        And what the f@#k is he doing reading my drive C:\?
          maybe?
          Thanks Needstorage, but maybe my computer skills arent what I thought because I don't understand what you just said
            What OS are you running this external disk on?
            Needstorage
              are you booting from the drive? or just using it for storage?
              if you're just using it for storage, you might not see it because there is no drive letter assigned to it.
              Start -> Control Panel -> Administrative Tools -> Computer Management
              Now, in the column to the left, under "Storage", click on "Disk Management"
              This will show you all the drives connected, if you see the drive there, but there is no drive letter, select it, right click, and go to "Change Drive Letters And Paths"
              From there assign a drive letter to the drive.
              After you have done so, it should appear under "My Computer"
                os
                Running win 98
                Just storage
                  what file system are you using on the external drive? NTFS maybe? If so that's not gooing to work in Win98 without another app.
                  Aura MR62 (F and R)
                  My Current MP3s
                  IamDefiler.com
                    Could Be Defiler
                    If that is the case D, do you have any ideas on the third party app I would need or where I could get it? the think was formated for 2000/ XP But I thought I heard that the newer format (NTFS) was backward compatable.
                      I am guessing that you want the stuff on the drive? if not why not just delete the partition and reformat the drive with FAT32, if you do need the stuff you can try this program
                      肚子笑痛了
                      S60 Install
                        exactly what I was going to suggest.
                        Aura MR62 (F and R)
                        My Current MP3s
                        IamDefiler.com
                          Oh, and NTFS is most definately NOT backwards compatible. It is the default format if you set this up on 2K or XP, and Windows 98 cannot read it. But if you format it on 98, then 2K and XP can read it no problem.
                          Chrysler 300 - Fabricating
                          http://hallert.net/
                            肚子笑痛了
                            S60 Install
                              another question is which version of 98? I am assuming you are using a usb drive. It has to be 2nd edition to use usb
                              '95 2 door Yukon
                              in dash Xenarc 700TSV
                              /w HP laptop
                              into (installed)
                              HU Alpine 9827 \ AMPS MRD-F540 + M301
                              MB Quart 216\213 + DVC 10 Sub
                              CarPC Pics
