Can I connect 2 amps to the same speaker
  • Can I connect 2 amps to the same speaker
    Could not find anything regarding the subject.
    I can't remove the HU (with built in AMP) due to the bus thing from GM, every thing will be disabled. So, the work around is to add a separate, secondary AMP for the carputer. question is, is it safe to connect the secondary AMP to the same speaker feed by the HU. I promise not to turn the HU on while the PC is on.
    Originally posted by kingtut
    is it safe to connect the secondary AMP to the same speaker feed by the HU? I promise not to turn the HU on while the PC is on.
    Well, I wouldn't test it if I were you. You could use some relays that will switch the source of the feed to the speakers. Then you are 100% safe. I do not know if they would add interference to the sound.
    Needstorage
    Who the hell is general failure?!?
    And what the f@#k is he doing reading my drive C:\?
      I agree, the relay is a much better idea. You might need to get a few of them, one DPDT for each speaker. If you get ones that have a 12v coil, then you could have them energize when the computer powers up. Run them off of a HDD power connector. Then when the computer is on, the relays switch the speakers to the computer. Turn off the computer and the relay switches back to the HU.
