dvd spec
  • dvd spec
    i been looking through the archives with referance to the lowest spec pc that will play software dvd without any problems but there does not seem to be a real solid answer.
    What is the lowest spec you are running
    Edie209
    Edie209
    http://www.ridgeway.plymouth.sch.uk/majikfish/majikfish.htm
    The reason that you cant find a solid spec on software DVD is that there is no solid minimum system requirements for it. Every part of the system effects performance: CPU RAM, grfx card, etc. Then again, if you are really worried, you can pick up a decoder card for ~$30....
    Car: 1999 Dark Green Mustang GT Coupe
    Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
    Player: Empeg for now; something custom later.
    www.neotechpc.com - Custom built laptops!
      You'd be safe with a 400-500 Mhz.
      My amd k6-2 350 ran dvds at about 20 fps.
      www.arbybean.com
        How you measure the FPS you are getting?
          I had a PII-350 that ran them flawlessly with just software decoding. It couldn't do anything else at the same time, so you may want to go a little faster. Also make sure you have DMA enabled to your DVD drive.
            I'm running a Celeron 600 II with 64MB ram, 16X slot loading drive, and a 16MB video card. It is quite crap on sodtware DVD playback, freezes, misses frames, sound drop out etc. Then I enabled the DMA on the drive, and it is a lot better, (well it's actually bloody nice) but it still stops every 5 mins or so, and the DVD spins up faster, and then it carries on. I can't seem to stop it doing this? But it just goes to show even a resonably fast machine is poor.
            Meatballman, how on earth did you get it to work on a PII350? was it smooth?
            BjBlaster! Car MP3 & Carputer!
            http://bjblaster.mp3car.com
            "The solution to one problem is only the begining of another"
            bjblaster.com
            "The solution to one problem is only the beginning of another"
              Celery chips suck at multimedia stuff. I can see a pII running it right at 350 but not a celery at 600.
              That 20 fps measurement was just kinda guess work. It wasn't super smooth, but it wasn't really choppy either.
              www.arbybean.com
                I have a 233mmx w/ 64megs that runs powerdvd smoothly. I dont have any choppy video. If you tweak your system and keep the system resources to a minimum..it should work fine.
                  Toxic - What vid card you running?
                  ~m
                  PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
                  Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
                  BC ROCKS!!!
                    <font face="Verdana, Arial" size="2">Meatballman, how on earth did you get it to work on a PII350? was it smooth? </font>
                    It was very smooth. If some program in the background kicked in, I'd get a frame glitch or two. I think older Celerons only have 64K (or 128?) L2 cache, whereas PII's have 512K. That makes a significant difference in multimedia apps. In case it matters, the vid card was a Creative 3DBlaster Banshee PCI, which is known for using very little processor power and the DVD was a Pioneer DVD-104S slot load. I successfully watched movies smoothly in both PowerDVD and XingDVD.
                      har.
                      i played dvd on my celeron 300a... at 300mhz.
                      of course.. that's with a scsi dvd drive. so that helps a lot..
                      it's as smooth as glass on my celeron 600
                      I cheat, I own an empeg.
                      Meskimen's Law: There's never time to do it right, but there's always time to do it over.
                      http://civic.mp3car.com
                        I couldn't smoothly run software dvd on my K6-2 400, but it did run perfectly at about 40% processor usage once i used a program that utilized my ATI card's hardware decoding. Now on my duron 700 i can get great playback both software and hardware as long as I have DMA enabled. It runs poorly otherwise.
                        Got started with computers on this board early in high school...now I run a web development company and am about to build my dream machine.
                          Nester: Your video card must have mpg decoding built in. (or smooth to you is 15 fps )
                          www.arbybean.com
                            Dos: its an ATI [email protected] PCI
