No one uses the EPIA-TC1000 or TC600, why?
  • No one uses the EPIA-TC1000 or TC600, why?
    I am trying to sift through the pros and cons of the different form factors, options, expandablitiy, flexibility, power, heat issues of a specific motherboard/processor combination and I'm surprised to see the lack of interest in VIA's TC1000 or lower power/heat TC600. I understand that the integrated 12V DC input does require regulation to design/build/test or simply buy a 8V to say 15V DC regulator is quite simple and inexpensive. Despite my [in]ability to find the TC1000 board at US $190 and assuming around $20 in homebrew regulator parts or even a commecial solution it seems that this path far offsets the price of an Opus or other such DC ATX power supplies. Assuming robust design on the regulator automatic boot and shutdown along with "surviving" cranking [read: having the computer not reboot due to the power supplies' inability to supply sufficient voltage to the motherboard] this board I think really deserves more credit. It also seems like for the price/performance and lack of headaches about heat and power this board offers it seems it would still come out shining.
    Basically I am interested in other people's thoughts on this. I have thought about using mini-ATX form factor custom built setups but using any kind of "modern" processor [read: Athalon XP or even higher speed Durons or moderate speed Pentium 4s or Celerons] introduces a good deal of cooling issues and power issues while using the mini-ITXs ease a lot of those concerns (along with still saving space, but you lose out as far as money but again after considering commerical or diy DC ATX power supplies the margins of saving are not that great assuming the use of all "modern" components]
    So this is a pretty confusing post because it's just off the top of my head after many months of pondering... so basically I just want to hear people's thoughts on this or anything you think I'm missing. Because I am sure I am and appreciate any constructive input.
    Also if anyone's trying to get an eGalax touchscreen to work with Debian [although many people here use Windows 2000 or XP] feel free to get in touch with me as well. Thanks everyone, I look forward to your comments.
    I see one major drawback to this board though, the lack of a decent on-board audio controller, it being only 2 channel and the sentiment on these boards that the on-board audio is bad anyway. Just thought I'd mention my own omission.
    When i saw the TC1000, i started regretting buying a lowly Epia800 (though i bought it second hand so i cant really complain). Onboard PSU makes for more space savings, and certainly costs less than getting a separate Opus.
    But i can think of 3 reasons why people would stick to the holy Opus:
    1) It can handle down to 7v or something like that
    2) It has shutdown/startup controllers.
    3) Onboard PSU for TC1000 is only 60W - means you are restricted to Laptop drives and minimal USB devices. Opus handles more
    However i'd take the TC1000 - Think of how easy it would be to fit that into a single din headunit!!!
    I think that the Carnetix CNPX2160 (or whatever it is - there is only one!!!), would be perfect for that. Its a 12V revulator which handles down to 7V as well, and has shutdown controllers as well!
    I know that if i started again, i would choose the TC1000...
      See above post by dominik:
      I own a tc10000. It is wicked :P I will, when it arrives, be using the carnetix psu which is far cheaper than the opus. Combined cost of this tc10000 and carnetix is cheaper than the opus and an mII 12000. I got the tc10000 with the pcmcia and compact flash adapter too, and so pop in my pcmcia wireless adapter and hey presto, i have wireless LAN to my car from my driveway.
      The onboard psu is indeed 60w. however, the board only consumes around 12w, say 20w max, leaving 40w for drives, usb, etc etc. I have, so far, managed to power:
      1x 3.5" 20gig hdd.
      1x 3.5" cd-rom
      1x GPS mouse
      1x touchscreen (usb also)
      1x dlink usb radio
      With this setup, i havent had any problems with power levels. Running winXP is good as I now use hibernate, which means boot time is less than 20secs from cold to music playing.
      From my experience, I cant recommend this board enough! Its tiny with onboard psu did it for me. Saved me getting a morex etc etc, and was a piece of cake to set up. Only problem I have had was getting compatible memory, as it doesnt use desktop ram, it uses DDR266 laptop ram, and can be picky as to what type, ie registered/unregistered, ecc/non-ecc etc etc.
      I would deffo go buy this board again!
      www.leoncupra.co.uk
        hey pabs... i'm having a problem with mine rebooting like crazy.
        i have a 3.5" 160 gig hard drive on mine and its regulated with an ITPS.
        other people on the forum said it was the hard drive making it reboot.
        are you having this problem?
        thanks.
        2001 Acura CL traded for a 2006 Subaru Legacy GT
        7" Lilliput Touchscreen
        NANO-ITX+m1-atx
        512 DDRsodimm
        60g SATA Laptop HD
        4x Apple DVDslot
        digimoto OBDii
        mS GPS
        mini BT keyboard
        relocated HU faceplate
          Where did you purchase your board? Also I notice that after looking in to the audio situation a little more you CAN apparently get a TC board with Via's VT1616 audio chip, as far as actual availability and price.... well yeah we'll see. My question is, is your board AC '97 codec equipped? Although I doubt I'll be watching DVDs or playing games with 5.1 audio output, it would be very nice to have this capability , especially given that a 5.1 setup in my car is very easy. Thanks and glad to hear this board's working out for you!
            Hi
            Not sure on the audio chipset on this. I am not at home and so will look when I get back and let you know. I remember reading tho that it is possible to make it spdif out, and hence 5.1 output. I am only using the line-out and it will feed several channels on an amplifier in the boot.
            Acura cl - Nope, not having this problem at all? Do you have the mains "brick" psu? If so, try using it at home without the itps. I have heard this could cause the problems.
            It depends on how much current your harddrive etc is drawing. I am not using an optical drive at all anymore as I dont need it (wireless LAN) but was thinking of getting a laptop dvd-rom from ebay for it. Just not sure on the interface connections... Can you just use the ide adapter from 3.5-2.5" drives?
            Your problem could be ur hdd as i see it is a 160gig. probably draws a lot. Find the spec sheet on it and find the required power (W) and see how close the whole setup comes to the max 60w.
            I also know that the RAM is picky. Have u tried a different RAM stick?
            Hope this helps.
            www.leoncupra.co.uk
              I do
              Then you only need dc-dc controler, not a complet atx power supply
              Plan for project = 100%
              Part the project. = 100%
              Built...................= 99%
              Finish.................= 99%
              Install ...............= 99% -50%
              Ditail at 4u2n.dk
              Here
                ___________________________
                YES
                  Good to hear that Pabs. I had seen people screaming power requirements left and right all the time... I always wonder if people actually ever read the data sheets provided with their components or before they buy them... of course you can't take the numbers 100% for sure but if the company is somewhat respectable you can go by the numbers supplied and as long as you leave yourself a bit of a margin you should be fine. This motivates me more to FINALLY place my order for this board. I still am angry that supposedly you can't run 800x480 resolution with the VIA onboard video... oh well crappy PCI graphics card is ok by me..
                  Also, I e-mailed VIA about the descrpency on their website and in their manual for the TC1000 board to try to see if I can get a TC1000 with the 6 channel chip... let's see if I actually don't go unnoticed :-P.
                    hehe....who knows?
                    To be honest, I dont have the entire system up and running yet, so more will be known when a)the psu from carnetix arrives, b)when i get my new car (v soon)
                    I have big plans, but they may fail yet!
                    I am running 800*600 OK on the xenarc, doesnt look too bad....
                    Will have a play around in a few days i expect...when i eventually go home that is.....
                    www.leoncupra.co.uk
                      What cases?
                      Originally posted by Mick
                      What are the advantages of using the carnetix power supply over just a sequencer/regulator like the ITPS? All the cases that I have seen already have a 12v DC-DC power supply, so I am just a bit confused I guess.
                      First off I'm a bit confused what cases you're talking about, if you could specify I may be able to answer you. As far as the difference between the Carentix and the ITPS I've read on these forums that the ITPS won't survive engine crank. Anyway though, I'm not an expert on these two products but go to carnetix website and they have some articles on it and things that are linked to these forums so you can safely assume they're not [too] biased. Anyway hope this answers you a little.
                        I'm pretty sure the Motherboard still needs 12v and will reboot if its not there. Basically the Carnetix regulator accepts from 8-20V where the ITPS only copes with 11-18 or something like that. If you have no need to survive cranking then i guess the ITPS would suffice...
                        As for the cases, i assume you are talking about the Morex cases etc. They all have Morex 60W PSUs in them, so you'd throw them out if you were using the Epia TC motherboards...
                          The ITPS will not survive cranking, and your PC will therefore reboot/shutdown everytime you start/stop the engine.
                          Also, and larger spikes from the battery will damage the board. It needs a constant, steady 12v.
                          If you want it in-car, Carnetix or Opus only.
                          Do a search on these forums. LOADS of info.
                          www.leoncupra.co.uk
                            thanks.
                            I have the TC10000, and was using the ITPS until recently. Basically the ITPS is crap. It puts such an insertion drop on the power I couldn't run the pc without the engine running. Even then the motherboard was only receiving 11.5v even though 13.8v was going into the ITPS. I've just received and installed the carnetix CNX-P1260, and it's an absolute joy! Even the cranking of my diesel doesn't bother it.
                            Tankslappa
                            Misubishi Shogun GLS 2.5 Turbo Diesel
                            VIA EPIA TC10000
                            80gig WD
                            Carnetix CNX-P1260
                            CarTFT/Lilliput 7" TFT - Touchscreen USB
                            MediaCar 1.91b
                              The motherboard itself is NOT a 12v component, it uses only 5v and 3.3v. 12 volts is only supplied for external 3.5" components such as a floppy, Hd, CD. etc. So, if I use 5v laptop drives, a constant 12 volt source does not seem to be an issue (correct me here if I am wrong).
                              In theory yes, but from my own tests on the TC10000, if you drop below 11.3v input, it starts playing up.
                              Voltage spikes on a 12v vehicle system are also something I consider to be extremelly rare if not close to non-existant. Case in point is that you already have a computer on board that controls the engine and it would be rendered inoperable if a "substantial' voltage spike were to occur.
                              Not so much spikes, as ripples. That's why people get whistles and whines from cheap car amplifiers which pick these up on the DC lines. Having said that I got so fed up with my ITPS failing to support my TC10000 I just bypassed and ran it from the native car 12v, only effect I saw was a slight rippling effect on the Lilliput.
                              Tankslappa
                              VIA EPIA TC10000
                              80gig WD
                              Carnetix CNX-P1260
                              MediaCar 1.91b
