one button
  • one button
    do you know how to config atx board and atx psu, so the computer will start when he get the electric from the battery.
    In bios, turn on "start when power applied" or "power on after regaining power".
    every bios is different, but it should have something in there about coming on when it gets power.
    www.arbybean.com
      Some boards have a jumper.
      Or sometimes, you can just jumper the power switch button.
      Gizmo-
      Techonlogy on Wheels
      http://www.hjnetworks.com/car
        On the boards that I have bought recently there is a setting in the BIOS that is for automatically starting when power is applied. This is encase the power is shut off and you want the computer restarted automatically without having to be there.
        Thanks,
        John
        JohnRam
        Check out: www.WindowsCar.com
        JohnRam
          You can just solder a momentary push button to the switch and run it up to your dashboard.
          Car: 1999 Dark Green Mustang GT Coupe
          Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
          Player: Empeg for now; something custom later.
          www.neotechpc.com - Custom built laptops!
            If i don't plug in the on/off switch on my board ,it's automaticly starts up when power is turnd on. Don't now if it works with other board's
            peter3
            [email protected]
            The Netherlands
            PETER - THE NETHERLANDS - DEVENTER
            sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
              Some of them, I think, are timed to restart within a certain number of seconds after power is restored. I know my board restarts after a brief power loss, but if you leave it unplugged for a while you have to hit the power switch again when you do return power.
