Making LONG RCA cables for interior walls?
  • Making LONG RCA cables for interior walls?
    I'm wiring my living room with some RCA cabling (I think). I am going to be running about 50 feet of right channel, 50 feet of left, and 50 feet of Video. And this is basically for my PS2 so I can just put it under the couch. (rather than having it dragged accross the room) After doing some searching I found THIS site that talks about making RCA cabling from CAT5. I wanted to know your opinions?
    If this is a horrible idea, what are some other options?
    thanks!
    BossTone74
    I dont know much about the quality of this but check this out
    http://www.trianglecables.com/75-foo...ono-cable.html
    :My Car and Regular Computer:
    http://home.comcast.net/~krypt2nite
      our church uses like a 100 foot video RCA cable, so I don't think that'll be a problem. As far as audio goes... cat 5 would probably work, it's been done. From what I understand, which is contrary to the myth, it's not sheilded in anyway, so you might run into issues, but other people say it sounds just as good, if not better. I say, what the heck, cat 5 isn't that expensive anymore.
      My Carputer! (More Car Pics at the end)
      2 Kicker Comp 10"
      Epia M-9000, 256 MB DDR, 120 Gig HD
      Lilliput 7" VGA Touchscreen
      Check it out?!
        I think you can buy that length. I am sure I have purchased 30 foot RCAs
        TruckinMP3
        Read the FAQ!
          Take a look at the gauge wires in RCAs compared to CAT5. The thinner the wire, the less signal you will be able to push through it.
          Here's my first link from a Google search for "50 foot RCA" and I came up with this: http://www.trianglecables.com/50footrcadua.html.
          You can find 2RCA, 3RCA, 5RCA (component), 2RCA with S-Video. Look for something that is Male-to-Female so you won't need any couplers.
          Derek
          Progress [||-------]
          View my Worklog to see some of my progress.
          Downgraded Progress - Starting with another car... 09/13/06
            did the shorter lenth of cable about 30ft. imo dont use cat 5. goto home dopot gat a roll of three wire lamp cord. use two leads for your rca and the third put an eyelet on and ground the eyelet to the chassie of your imput device ( tuner,amp,ect)
            NOT THE PC.
            keep all audio cables at least 8 inches apart and 12 inches for the video.
            if you can try to use optical for your audio
            also at those lenthes you may also need a distrubition amp, get a adjustable with discret chanels, so you dont over drive the video when try to get audio level proper.
              y not jst buy rca wire in a roll? then put some connecters on each end........
              92 Subaru Legacy Wagon
              Epia MII12000 :D
              Morex 80W
              120G External HDD
              16x2 Charater Display
              Creative IR Remote
              VIA Sereniti 2000 Mini ITX Case
              7.2Ah SLA Tank
              PCMCIA 802.11b
              256DDR Ram
              Diamonds are for girls- wise men follow the stars
                search. there was a very very long discussion about the use of cat5 cables for audio.
                I wouldn't do it. Others have done it and think its fine.
                car computer rev 5: 8" lilliput and usual suspects
                  If anyone is interested...this is what I did with about 60 feet of CAT5, I got left and right audio and 1 video line from it and it looks and sounds great! (through my PS2) Man SOCOM is SO GREAT!
                  http://www.s10forum.com/forum/showth...threadid=32896
                  BossTone74
