RE-solder USB?
  • RE-solder USB?
    My USB connector got bent at a 45 degree angle. Plugging that in fried my old mobo. So I need to repair the usb connector.
    Can I REpair the connection like this..?
    I need to get a usb extension cord.. like 3 ft or somthing. Take apart my current broken end connector and solder the 4 wires that come off the usb onto the usb extension cord that i will also take apart...
    Does that sound right,
    Am I risking frying more things??
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    The cable on my usb-ide adapter got bent at 90 degrees, and now all 4 wires seem to be connected. I'm going to be doing this exact thing tomorrow, then I should have my DVD drive working again.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
      alright.. well get back to me on if it works or not, thanks
        A lot of usb wires are small...I mean REALLY small. Soldering those things nicely is annoying...I'd suggest you use something anchored to the outer insulation to protect against accidental pulls, depending on the wire size they may break really easily.
          impatient cow:
          MOOOO
            Yes, it will be very easy to fix, just 4 wires and if you know how to solder you should be set. Color codes are usually an industry standard. Make SURE to insulate ALL of the wires with good heat shrink. I would also reccomend coming out about a foot on the new section of cable, so your joints are not right at the usb plug. Keep it back a ways to prevent any bending problems.
            2005 Ford Focus ST
              Well I didn't need to re-solder mine, none of the wires were bad
              But it's real simple to do
              Garry
              www.aimee.cc
                I think you will also need to solder the outside chasis of the USB plug to ground. Im pretty certain USB also uses that as a sort of '5th wire'.
                Have a look on the board where the plug was soldered on, if you see a track where the mounts are then you will need to do the above mentioned.
                Car PC v1 - 1999 - 2000
                DOS 6.22 - MPXF - 2x16 LCD - 6.4GB
                Car PC v2 - 2002 - 2006
                XP - 7" wide/touch - GPS - Tank batt relay - 100GB
                Car PC v3 - 2008
                XP - 7" wide/touch - GPS - 802.11g - FM/XM - OBDII - WWW
                [||||||||||||||----] 80% complete
                  hmmm... okay, well as opposed to soldering, i was able to bend the pins back into shape... but my computer isn't recognizing it when i plug it in...
                    ....is there anyway i might be able to solder on a new connector.... using only the wires coming from the cable...?
                    I really don't want to buy a new GPS
                      just splice the wires inside the insulator on the cable and solder them directly onto the board if you like.
                      Personally I wouldnt do that and id have some sort of plug there instead of a static connection. Even if you cant find a USB connector, just use any other sort of 5 pin connector (including the chasis for ground).
                      Car PC v3 - 2008
                        So your saying... cut my current cable.... solder on a new cable that has a new connector on it, and then plug in. Right?
                        if so... How can I tell which wire is which?
                          Colour code. there should be a red (+ve), black (-ve), green (data+), white (data-). and a braded sheeth (earthing).
                          Just a question, how did you bend it?
                            everything is mounted on a hinged board in my trunk. It was fine in the upright position, but when the board slipped down to the down position. there wasnt enough slack in the wires
                              They make connectors now! Here's Type-A if it's of any help.
