Is this hardware all i need?
  • Is this hardware all i need?
    Ok i'v got the LCD screen but i need to find the hardware
    http://cgi.ebay.com.au/ws/eBayISAPI....06645&tc=photo
    would this be ok?
    Its a VIA EPIA Mini ITX MII 6000 Motherboard
    with this powersupply?
    http://cgi.ebay.com.au/ws/eBayISAPI....12054&tc=photo
    Its a Morex 80W power supply for a car
    Now would the powersupply be ok when the car cranks? it looks like it should from the descriptions
    and the motherboard would that be fast enough for Destinator with media car playiong mp3's ??
    Also is 80 watts enough power for the motherboard usb GPS reciever and a laptop hdd (i know a CD-ROM/DVD_ROM wont work)
    I only started this about a week ago and i can never wait long to finish it so are these all i need?
    Thank you
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Your question is very open and vague. What all would you like your system to do? What do you mean when you write "i know a CD-ROM/DVD_ROM wont work"?
    My Install Thread
    digitaljetta.com
    MKIV VW Jetta
    How do I get sound to my car?
      You probably want to go with the 1GhZ Via board the one you found might be a little slow for GPS and Mp3s at the same time. As for the power supply I'm pretty sure the morex power supply won't survive engine crank. As for whether or not it would be enough power check out www.mini-box.com and click on EPIA power simulator to figure out your power requirements.
      EPIA MII-1200, 512 MB Ram, Seagate 7200 RPM 160GB hard drive, Orinoco Gold with 5.5 dB external antenna, Lilliput 7" TS, DVD-ROM, M2-ATX, Rikaline 6010 GPS, Running Frodo Player
      My Truckputer
        What?? You better check your OS and setup. I can run GPS and MP3 together very smoothly on my 5 year old PII 266. It also decodes DVDs and DivX perfectly. Now I have a newer CPU in my carputer but I think 1Ghz is extreme over-kill for a computer just doing MP3, Video, DVD, and GPS. I don't know too many people who are rendering gigabytes of 3D in their carputer.
        My Install Thread
        digitaljetta.com
        MKIV VW Jetta
          Im sorry i was vague
          i want to know if 600Mhz with XP is enough to run destinator and MP3 at the same time using media car?
          Also i'm only using it for MP3 GPS and maybe DIVX
          thats it no DVD
          The ebay auction for the power supply says it can't run a CD-ROM cause of the power.
          This is the only thing i can really get in australia so will this be enough for GPS and MP3 at the same time?
          CarPC Status:
          GPS: 99%
          Hardware: 99%
          Software: 92%
          Case Install: 99.9%
          Dash Install: 100%
          Car Install: 72%
            Yes 600 is more than enough. That's what I use myself in-car. If you read my post above you'll see that I did all that succesfully with a 266 PII.
            You may be able to run a slimline optical drive.
            My Install Thread
            digitaljetta.com
            MKIV VW Jetta
              If you're asking for budgeting reasons, don't forget all of the cabling and other nic nacs that you need to complete the install. All of this could add up after awhile.
              Things like:
              AUX input converter for your head unit - if you plan on keeping it and it doesn't have RCA inputs
              AMP - if you plan on ditching the head unit
              CABLES - USB extensions, AMP and/or Power supply power cables and grounding, etc etc
              I know I overlooked all of these costs and my head started swimming all of the different times I had to whip out my wallet.
              mATX mobo
              2.4 GHz Celeron (prescott)
              512 MB RAM
              80 GB 3.5" HD
              Runnin off an inverter (for now)
              7" Lilliput
              Microsoft (Pharos) USB GPS
              Have yet to pull the trigger on a slim slot load DVD
              STATUS: who knows... I don't
                Thanks for the help guys
                i searched the forums and found the morex 80w power supply does survive cranking
                Im not on a budget but i dont want to spend to much money on it either
                now i cant wait for the stuff to come
                im a impulse buyer :P must get everything done now
                CarPC Status:
                GPS: 99%
                Hardware: 99%
                Software: 92%
                Case Install: 99.9%
                Dash Install: 100%
                Car Install: 72%
                  oo calm down, don't want to rush and buy just anything!
                  CarPC status: iPod, 3,456,217 songs so **** you
                    to late
                    CarPC Status:
                    GPS: 99%
                    Hardware: 99%
                    Software: 92%
                    Case Install: 99.9%
                    Dash Install: 100%
                    Car Install: 72%
                      256mb of ram is enough if i have XP installed?
                      im sure 128mb would run xp and media car fine just wanna check
                      CarPC Status:
                      GPS: 99%
                      Hardware: 99%
                      Software: 92%
                      Case Install: 99.9%
                      Dash Install: 100%
                      Car Install: 72%
                        If you aren't on a strict budget, consider the Opus power supply. It's super.
                        The more RAM the merrier.
                        Chrysler 300 - Fabricating
                        http://hallert.net/
                          As stated above im an impulse buyer
                          I'v already brought a 7" LCD
                          motherboard cpu ram and powersupply and GPS all in the span of a few days
                          so its a bit to late to reconsider
                          But thank you for all your help
                          lets hope i havent screwed up
                          CarPC Status:
                          GPS: 99%
                          Hardware: 99%
                          Software: 92%
                          Case Install: 99.9%
                          Dash Install: 100%
                          Car Install: 72%
                            256MB will run XP with no problems.
                            Get more RAM if you can, though.
                            How about the Wiki?
                              whats good GPS receiver to get and where from can u order them ?
                              tnx
                              [|||||-----] 95% complete
