wake on modem ring help
  • wake on modem ring help
    i found out that my laptop has no serial port. but it does support wake on modem ring. is there any way to feed it some sort of small voltage to wake the system up. any ideas where to find more info on how to do this. thanx a ton
    smonice
    Land Rover Discovery I SE7
    800MHz Laptop, 384Meg Ram, 160Gig Ext HD
    Lilliput 7" Touchscreen
    Built in Wireless and Cell Phone Net Connection
    Click Here for Pics (not up yet)
    anyone????
    smonice
      Installed.
      -GPSSecure- - GPS Tracking
        i cant find anything on google. my laptop has what looks like a 2 wire modem input but i cant find ANYTHING on the net about what voltage to pass over this to get the cpu to wake back up. Thanx a ton.
        smonice
          http://www.epanorama.net/documents/t..._intercom.html
          its how to connect 2 telephones for a intercom without using any phone lines.
          Down further it explains how to make the phone ring which is what u need
          only problem is it needs alot of volts and the way to ringing works is a certain frequency so if i made that it would wake the pc up
          CarPC Status:
          GPS: 99%
          Hardware: 99%
          Software: 92%
          Case Install: 99.9%
          Dash Install: 100%
          Car Install: 72%
            40-90V seems like way to much for those small wires. Any other suggestions??
            smonice
              You have a built-in modem, it's not quite as easy as having a com port to play with! One solution is to solder wires onto the on/off switch inside the laptop or docking station. (a docking station may give you a com port)
              Laidback
              The ultimate CarPC - Wow!
                but im having a problem trying to find the pin outs for the switch under the lid to soldier my own switch to. any idea?? it is a 4 pin switch and i have measured the voltages when the switch is depressed and no voltages showed up higher than a clear 0V???
                smonice
                  It's probably just shorting two pins together, rather than creating voltage. Put your multimeter into "Circuit" mode and make it beeeep
                  Garry
                  Co-Developer of A.I.M.E.E
                  www.aimee.cc
                    ok ill see what i can try, leads are vry small as well, guess i better get good at soldiering. if i link a momentary switch to this, will that work. thats what i got from another post??
                    smonice
                      This is the voltage of phone line though. I have multimetered a phone jack before and its something like 50V at a dialtone and supposedly double that at a ring. Not very high amperage obviously.. the hard part may be trying to generate that kind of voltage in the car ouch.
