another video card quetion
  • another video card quetion
    im looking for a good video card for my asus A7N8X-E Deluxe mobo the agp has to be 8X (1.5V only). can someone give me some advice on which to get. i mainly watch dvds and sometimes (when i can get reseption) tv. just need some help on what to get. thanks sam b.
    Best Technique In Life Is Having No Technique
    ONE DAY I WILL LEARN HOW TO USE THE COMPUTER THE RIGHT WAY.
    No need to get a 8x AGP videocard for DVD playback or TV tuner. Save your money and use a PCI slot.
    My Install Thread
    digitaljetta.com
    MKIV VW Jetta
    How do I get sound to my car?
      Well, if you allready have an AGP slot, get an APG card. Save those PCI's for wireless ethernet or something else to take some bandwidth off your USB.
      I've had good luck with the ATI all in wonder series. They have a lot of functionality and come with some good software packages. Dont need to go insano and get the 9600 AIW- I have the 7500 and it works fine. BTW- Your mobo supports 8x AGP but doesn't require it. It should be backwards compatible with 1X,2X,4X modes.
        yeah but i also dont want too much power drawn from the agp card.
          i may be wrong, but isnt 1X incompatable with the others?
          AMD XP 2000+ 512Mb Ram MB:A-7VM400AM-RZ
          Zenarc 700TSV Netgear USB WiFi GPS Opus 150
          Running Win XP, FP, MM
            Yes!! 1X-2X can not be used with newer 8X and agp PRO, only 4X-8X.
            2-15" ILO lcd w/DVI
            6800 gt Duel DVI out
            p4 1.6ghz flex atx board
            1gb 400 ram
            120gb(2-60gb raid) sata hd
            2-60gb hotswap
            WIN2K Pro SP2
            M.A.M.E. w/2,300 games
            CARPuter info
              Right.
              Doesn't matter though unless he decides to buy a used card.
              If I were you I would go to pricewatch.com and buy the cheapest video card you can. Unless of course you want to watch TV. Is this for your home PC or is this going in you car? If it is going in your car you are going to have to buy extra equipment to watch TV. To me it doesn't seem worth it. If not, there are a lot of cards that have TV tuners. Any new card will allow you to play DVDs.
              Installed.
              -GPSSecure- - GPS Tracking
                AIW: http://www.newegg.com/app/viewproduc...102-345&DEPA=1
                or:
                Personal preference for video card and a capture card:
                http://www.newegg.com/app/ViewProduc...100-003&depa=1
                  this is for my car.
                  pip those will not work for my car it has to be for a xga screen so i would need a vga port.
                    Originally posted by streetknight
                    this is for my car.
                    The top link that pip posted includes a dongle that goes from their half-sized DVI-looking port to standard VGA. ATI calls it the 'output adapter'.
                    And if you'd read the product description or even looked at the pictures, you'd know this.
                    How about the Wiki?
                      well i did read it but i went what his Personal preference was and i went with that. the aiw i did not know that and from the descrition i could not tell. it just says this Ports: CATV In+A/V Out+A/V In
                      so chill out ppl make mistakes
                        what about say for an EPIA M10000 board. The onboard video is a bit slow, and I plugged in a FX5200 PCI card into the PCI slot (only one on this board) and it wouldnt boot!! Doesnt like the power requirements.
                        So what video card would be more siutable? quicker than the onboard video, but not overcome the power supply. (power supply is a 200watt plug onto motherboard version from ITX)
                        cheers
                        Ford XR6T blueprint 4.0 L twin cam turbo.
                        Xenarc 7" touchscreen M10000 Audigy 2 NX
                        ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
                        Griffin Powermate Panasonic DVD-CDW
                        Pioneer 5x7 Four way, 2x12 pioneer subz
                        600watt 6chan USA audio AMP
