car ac control integration
  • car ac control integration
    hello this is my first post to mp3car.com
    my question is I would like to use the serial port or parralell port of my carputer to control my ac in my 98 dodge neon I am currently using a serial relay unit for the blower motor and floor to defrost switch but i have 2 rods that do the temp and inside outside air flaps. i have looked into stepper motors but am not familliar with there programing. could someone help me with this if i can get rid of the ac control knobs i can upgrade to 10.4 lcd touchscreen thank you dave
    sorry to make a new thread but did not find another to attach to
    You already have it setup so you can control fan speed through PC via serial?
    My Install Thread
    digitaljetta.com
    MKIV VW Jetta
    How do I get sound to my car?
      Here you go:
      http://www.parallax.com/dl/docs/books/sw/exp/sw26.pdf
      Check out my hopefully useful site...
      www.hobbybotics.com
      It's still under design but it is functional
        yes i have the fan speed and blower motor controled because in neons it is controled as a switch and all you have to do is setup a serial port relay here is the one i used
        http://www.audon.co.uk/som1.html
        linked with profit lab software http://www.audon.co.uk/profilab.html
        it is easy to make a grafical interface it doesn't look cool but i am working on that
        thanks brooksware
          Instead of a stepper motor turning mechanical knobs, how about bypassing that? Just a thought ...
          If they are potentiometers you can build circuits to emulate the resistance that turning the knob would do. If they are switches, you can build relay circuits that will operate pretty much the same way. Less to go wrong.
            the blower and the selector for floor,vent,head,and defrost are switches the hot,cold and fresh,recirculate selector is a real mechanical element that is connected to a flap I would need a stepper motor or liniear motor or something to push=pull to give the desired effect I thought stepper motor would be best because i could not only select hot,cold but a thousand other variations in between the fresh-recirculate could be driven linearly because it is either one or the other. i am researching the stepper motor info that was given above but does anyone else have an idea about another form of control
              Originally posted by 2nau-t
              Does anyone else have an idea about another form of control ?
              Servos if you can find them powerful enough.
              [H]4 Life
              I'm a lesbian too.
              I am for hire!
                Yeah, servos. They take up less power to operate than stepper motors and they are cheep as chips.
                Also, they are very precise. You can set them to the same position over and over and they will not fault.
                Stepper motors on the other hand need an encoder on them so you can work out there position, else you might end up breaking something.
                  here is a serial servo controller (uk) http://www.maplin.co.uk/products/mod...moduleno=20461
                  can controll up to 8 servos useing the serial port
                  or direct from the manufactures
                  http://www.milinst.com/animatronics/...m#servodrivers
                    USB
                    http://www.phidgetsusa.com/viewproduct.asp?SKU=1001
                    [H]4 Life
                    I'm a lesbian too.
                    I am for hire!
                      Ooo, serial is cheeper tho
                        thanks for the post guys the serial port does look cool but i already used it up for the switches the usb is cool though and phidgets has a usb 4 port relay usb board just what i whanted thanks. hey frodo any chance of helping with the soft side of things i know u are good with gui's and the software i am using for the switches realy is'nt for touchscreens
                          The monkey is not allowed to work on any other projects until 1.09 is done--in accordance with the prophecy
                          Ashley Powers did what you are trying to do in a Mazda pickup, and that was a good 5 years ago at least
                          http://www.ashleypowers.com/
                          Debt as of 1/1/05: $34,354.48
                          Debt as of July 4, 2007: $0.00 explanation
                          I'M DEBT FREE!!
                          I'm now a reasonably successful gunblogger.
                            blah no software links wizard
                            this from a guy who has dryer vents running to the back of his car!
                              Phidgets are super easy to program for, you should need no help.
                              [H]4 Life
                              I'm a lesbian too.
                              I am for hire!
