Laptop vs MINI ITX PC
  • Laptop vs MINI ITX PC
    Hi all. Just wanted to hear some opinions about the advantage of using MII 10000 board vs a regular IBM Thinkpad (lets say... t22). You can get a used T22 on eBay for about... 300-400 dollars. You WILL spend much more money building a custom computer and from what I understand P III 900 (in T22) will outperform VIA Processor.
    Well that wouldn't be very fun...
      I just bought a Lifebook B2562 it has a 10.4" Touchscreen so you dont need a expensive liliput the display supports 1024x768 it has a 700Mhz PIII 256MB Ram and 20GB HDD so that is quite enaugh for a car pc and you can not only use it in car :P i hope ill recive the notebook tomorrow so i could tell you more then. I only have tu build my custum car holding .
      Golf 3 CarPc Status
      ///////////////50%--------------/
      PSU:Inverter
      GPS:BT GPS
      PC: Slim notebook with 10.4"touch, external DVD.
      Dock for car is in production.
      Audio: Stock speakers but looking for new ones. CD-HU with FM modulator (ordered)
        Well... I have Thinkpad T23 in my trunk but I am still using Lilliput. First of all it is much brighter then regular LCD panel and it just looks SOOOO much better in my car
          I don't mean to be a "hater" but what fun is that? How do you plan to intergrate into your car audio? I can't image that "holder" and wires hanging everywhere are going to look very good.
          My Install Thread
          digitaljetta.com
          MKIV VW Jetta
          How do I get sound to my car?
            ill tell you how i use it i only have to plug in 1 USB wich is connected to a hub wich is connected to USB-Sound USB-GPS and the power and serial ports are in the dock wich is permantly monted to the dock :P
            Golf 3 CarPc Status
            PSU:Inverter
            GPS:BT GPS
              The main reason that I would change my setup (a laptop) is that you are pretty much stuck with what comes with it, at least for video. The video card in my laptop is crap, and I REALLY dont like having everythign streched in windows (powerstrp doesn't support the video card). I am also getting some noise (fairly minor) from the HDD that I can't seem to get rid of, even with an external soundcard, though I don't know if this is specifically related to the laptop
              I have a laptop with a broken screen, so it is (going to be, when I figure out how to do it) permanently mounted and hidden from view. I opened up the case and I have wire connected to the screen sensor and the power switch, giving me a lot of options for controlling startup/shutdown/suspend/hibernate.
              Because it runs off an internal battery, I dont have to worry about cranking issues. Laptops are generally designed with lower power components, though I have no idea what the difference in power draw is. Depending on the computer, you can get dc-dc power supplys fairly cheaply.
              |V1 Virtual Display|
              Hard work often pays off over time, laziness always pays off right now.
                i just bought a tablet PC off ebay
                fujitsu stylistic 3500
                hopefully it will work well as both a car computer and for a scribble pad for taking notes at university
                500mhz celeron 192mb ram 15gb HDD win2k 10.4inch touchscreen
                hopefully it all works out
                  I was looking for a tablet pc too and fujitsu stylistic 3500 sounds good. What about the "sound" output, have u ever try to play DVD/DIVX on it? What about the pen?
                    My last carputer was an EPIA/Opus configuration which was great. My new one however will be a laptop.
                    I think that the EPIA/Opus solution is superior, more flexible, and more fun. However my new car is notorious for eating battery, so I don't want to risk draining it further. Also the boot (trunk) is so small that I don't have space for a secondary battery to aleviate this.
                    So, a laptop with port replicator and lilliput up front it is. Just need to get me a laptop now.
                    GingerPrince
                    Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
                    Carputer Install - http://www.stuffandting.com/carputer/
                    CarBox Software -- http://www.stuffandting.com/carbox/
