Couple of questions
  • Couple of questions
    1. For some odd reason when I had the carputer mounted it only came on once in a while, it was not consistent at all. I'm running an ITPS.
    2. Also, my enclosure was not up to par AT ALL, due to the monitor that I'm running I have to use a video card with TV out (composite) or either get another mother board.
    Right now, I've spent enough money that this setup has to stay.
    any advice or comments?
    http://memimage.cardomain.net/member_images/2/web/170000-170999/170063_221.jpg
    whats the Wattage rating of your PSU and what components are you running on it? It sounds like you either have a bad connection with your battery and PSU, the ITPS isn't working, or you have over worked your PSU.
    [addition-->] After reading it again, it sounds to me that you have a bad connection with your computer either by PSU and battery or PSU and mobo. I would check those.
    If you didn't have fun when you were living, were you really alive?
    {[X-----------------]} 25% Complete (Plan Made, awaiting funds)
