Creative Audigy and VIA MII 10k sound
  • Creative Audigy and VIA MII 10k sound
    Dear all,
    Although I am happy with my Audigy NX, it is a shame that the Line In and Mic In share the same input
    Is there anyway I can use the onboard Mic Input while still being able to use the external Audigy NX?
    Andrew
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
    You can use the onboard mic input. Just make sure the program you are using it has it's settings to use that sound source. You can also choose in windows what sound card is used for input and output. Check the sounds control panel. There should be a drop down menu. I'm not sure if you can use two simultaniously, though.
    My Install Thread
    digitaljetta.com
    MKIV VW Jetta
    How do I get sound to my car?
