Which VIA motherboard is the best????
  • Which VIA motherboard is the best????
    I want the fastest,
    best all round performance & compatability.
    Price is not an issue.
    Here are the choices:
    MB-P3-VIA-E-CL10K VIA CLE W/C3 1G NEH 2-L/VGA/AUD/TV CL10000
    MB-P3-VIA-E-CL6000 VIA CLE266 W/C3 600 2-LAN/VGA/AUD/TV CL6000
    MB-P3-VIA-E-M10K-N VIA CLE W/C3 1G NEHEMIAH FW/VGA/LAN/AUD EPIA M10K-N
    MB-P3-VIA-E-M2-10K VIA CLE W/C3 1G EDEN VGA/S-vid/LAN/AUD MII 10000
    MB-P3-VIA-E-M2-6KE VIA CLE W/C3 600 EDEN VGA/S-vid/LAN/AUD MII 6000
    MB-P3-VIA-E-ME6000 VIA CLE266 W/C3 600 CPU VGA/LAN/AUD/TV EPIA ME6000
    MB-P3-VIA-E-TC-10K VIA CLE W/C3 1G NEH w/CCM01+LVDS01 TC10K
    MB-P3-VIA-E-TC-6KE VIA CLE W/C3 600 EDEN w/CCM01+LVDS01 TC6KE
    MB-P3-VIA-E-V10KA VIA w/C3 1G CPU,VGA/LAN/FDD/AUD V10KA
    MB-P3-VIA-EPIA5000 VIA PLE133 w/VIA C3 533 CPU,VGA/LAN/AUD EPIA5000
    Which would you choose?
    bump
      You forgot the MII-12000. Thats the one I went with because it had the fastest CPU clock speed and PMCIA/CF onboard.
      The 2007 Scion tC + Infill G4 Project | DVDxml.com
        I second the MII. I have the MII10000 and I'm very happy with it. Much easier to do a wi-fi card instead of a usb version.
          bump ...
          thx for the suggestions.
            If you want a VIA board i would wait until the EPIA-SP comes out. It will perform a lot better than any previous one, plus it has SATA and DDR400 support.
            http://www.viaembedded.com/product/e...herboardId=261
            But if you can't wait, i would by a MII.
            I used to have a M10000, but upgraded to a AMD based microATX mobo. Mainly becuase i require more grunt for games and it works out cheaper.
            We are, will have and forever will be...
            But not tommorrow!
              That's what I'm doing
              PowerVoice v1 | NaviVoice Source
              GammaControl v2.4
              SKINbedder v3
              1995 Lexus SC300
                Originally posted by Diewlay Lowmo
                I want the fastest,
                Get a non-VIA board then.
                Installed.
                -GPSSecure- - GPS Tracking
                  Other ones are noisy because they need a lot of cooling
                  GammaControl v2.4
                  SKINbedder v3
                  1995 Lexus SC300
                    Depends on what fan you get. They don't need more than a standard heatsink/fan. There are plenty of heatsinks/fans out there that are quite, just check the db rating. Plus if you have it in your trunk you will never hear it anyways.
                    Installed.
                      I'm shoving mine behind the LCD, so it will always be in the cabin. I need something that will be quiet. The EPIa fans are always quiet, but you can also undervolt them even more And they don't take up a huge ammount of space like coolers for AMD/Intel ones.
                      GammaControl v2.4
                      SKINbedder v3
                      1995 Lexus SC300
                        panaflow fans rock .... search for a local company called bigfootcomputers.
                        So far it seems that this is the best option. I can only buy whats on the list above:
                        MB-P3-VIA-E-M2-10K VIA CLE W/C3 1G EDEN VGA/S-vid/LAN/AUD MII 10000.
                        Does anyone see a better option on that list?
                          No, if you have to buy from that list, get the MII-10000
                          My Car
                            is there a parrot in here?
                              New Via Boards
                              Anyone hear when the SP and other new boards are due to come out? I keep seeing references to September but I also have read that they are notoriuosly late. Anyone have any updates?
                              -B
                              My Install
                              Software:
                              CFiG v1
                              iGuidance Plugin for CF
                              CarShell
                              Working shell for a CarPC
                              StopWatch
                              StopWatch plugin remade for centrafuse RC1
