idea
  • idea
    just been messing around with my system and I came up with an idea!
    If I connected an led to the speaker connector on the M/B then I would have a Visual POST. This could be handy at the front of the car if there are any booting problems.
    Then I thought why not go further you could have an audio bleep to confirm inputs that would flash the LED confirming the input has been recieved.
    I have just connected on my system seem to work really well.
    Just an Idea??
    Edie209
    Edie209
    http://www.ridgeway.plymouth.sch.uk/majikfish/majikfish.htm
    Unfortunately that is not going to work. You could connect an set of long cables to the power and hard drive led's to see them.
    John
    JohnRam
      I did mean with long cables, not directly connected to the M/B
      Edie209
      Edie209
        Been there done that....
        Took a picture
        http://www.hjnetworks.com/car/control.htm
        Gizmo-
        Techonlogy on Wheels
          I picked up a keypad which does not have a NUMLOCK LED. Is there any way to access NUMLOCK status from the MoBo? I am thinking of installing something similar to gizmo's setup, but would also like NUMLOCK so I can double up on control options.
          The old truck is on this page. New one to be updated as time permits.
          http://www.geocities.com/avgeek94
          KG6OQD
          www.americansandassociation.org
            Back in the day, I knew of a DOS TSR that swaped the numlock led and HD led 's
            You could probably find it on some old dos shareware cd's
            Gizmo-
