in-vehicle PC
  • in-vehicle PC
    hey
    i've been working on new in-vehicle PC see the file attached. Suggestions, comments???
    US$ 1215)
    Includes complete installation by qualified technicians
    bravo... I saw one @ Electronics express. fully motorized (the display that was an actual dashboard)
    It was a dvd/HU/nav basically... I think it was $1700
    1200 ~ 1700
    Your unit is Awesome! ~and I wouln't mind it in my car one bit
    What is the price without install? & how much is the replacement for the in dash part of the system?
    Ghetto Sleds Turn Heads
    PimpED OutneSS ProGress O' MetER
    --22%--------!
    (still noobin')
      I have a few questions...
      Why are you using an inveter? Do you include a startup & shutdown controller? Does it survive crank? Also, is this all theory that it all works how you plan? Have you done a installation and worked out all the kinks?
      My Install Thread
      digitaljetta.com
      MKIV VW Jetta
      How do I get sound to my car?
        re
        price for 7" in-dash TFT LCD is about US$250. yep u read right. because it is not big brand name like panasonic etc. it is customized just for VGA input.
        installation is quite cheap about $50. what u would pay to install a normal radio + amplifier. This PC installs easy because the monitor is 1 DIN size (standard radio slot).
          hello
          good question about inverter. well, so u can unclip computer and use it indoor or wherever for mains power. the 220VAC PSU is still inside the chassis. inverter may not be most efficient, but costs in South Africa are much better than DC-DC converters. power source is directly from vehicle battery with own cables, avoids any interference of electrical system. it has permanent power(unswitched), shutdown/startup by user input or delay( motherboard bios/WinXP), working on ignition startup.
            I've run both an inverter and an Opus PSU in my car... the Opus is infinitely better... you end up with a massive hassle factor when you're using an inverter in my experience. If you want to use the PC indoors at any time, just attach a normal AC PSU... it'll only take 10 seconds.
            Other than that, the system looks excellent... you're gonna have a blast! Looking forward to seeing the finished article!
            Celica VVTi
            EPIA M10000 Nehemiah, 160Gb HDD, 7" Lilliput VGA Touchscreen, Opus 150Watt PSU, Slimline DVD/CDRW, Road Runner
              You end up with a massive hassle because u guys dont want to fixx the problem and want to go the easy route and get something that does it for you.the inverter is cheaper plus it powers a more powerful computer system.
              2-15" ILO lcd w/DVI
              6800 gt Duel DVI out
              p4 1.6ghz flex atx board
              1gb 400 ram
              120gb(2-60gb raid) sata hd
              2-60gb hotswap
              WIN2K Pro SP2
              M.A.M.E. w/2,300 games
              CARPuter info
                @ $250 for a motorized, indash, VGA, touchscreen. I would buy one right now.
                ,./(0)3
                '04 Canyon 4x4 pickup
                [---PC on hold----working on external fiberglass "tool" box---]
                  over $1200 ..... man that is spendy. Sure it does everything but that is a lot of money.
                  TruckinMP3
                  Read the FAQ!
                    I'd still buy the screen for $250. Any chance of that happening? PM me I need to buy a screen in the next few days.
                    ,./(0)3
                      re: screen
                      unfortunately the 7" in-dash motorized monitor will only be available from end October. but i will keep posted. should u be still interested by then i can send you technical specifications and more pics once i have a unit again. i think we can manage to supply you one.
                        I'd buy a lot of those screens if the quality (both image and build) is as good as the new xenarcs....
                        Let me know!
                        List of front-ends/usefull apps
                        XTroniC | XTroniC Direct
                          I'd be all over that myself. Would save me a few hassles.
