Offered a complete epia 1000 board.....good deal?
  • Offered a complete epia 1000 board.....good deal?
    ok, i've decided to devote my time into a carpc and will begin late october, but i dont have a mini pc built for the carputer yet.
    I was offered a pre-built one that is apparently like new and was going to be used in a carpc but he's going to ditch it.
    The cost of this will be $250.......please tell me if it's a good deal:
    Included:
    - Via M10000 EPIA Motherboard/CPU
    - 256MB DDR ram Crucial/Micron stuff
    - 20gb Laptop HDD
    - 12v DC-DC Power Supply (specifically this one http://store.ituner.com/ituner/posoformi.html)
    - Custom plexi case I made for it to fit in the drivers side knee panel in my car. Case is tiny, check the pics.
    - IMac slot load DVD Drive (must be used externally, case is too small) I had this wired straight to the long IDE cable you see out the side of the case and lived in the center console right under my LCD display.
    - No *optional* LVDS connector on the board
    he says he doesnt know the output of the system, but it worked fine when he booted it for testing.
    I just plan to use the carputer for emulation, dvd, gps, and music.......is this sufficient and a good price?
    here are images of the PC- the fourth picture is the external dvd
    Sounds good to me.
    New 20gig Toshiba - $71 + shipping
    M10000 EPIA MoBo - $175 + shipping
    Power Supply - $30 to $50 + shipping
    256mb Ram - $40 to $60 (crucial is free shipping)
    So just at that you're already saving some bucks.
    I think it would be powerful enough too. I have an EPIA 800 and it does everything I want it to do. And big differences between my board and yours? Processor and video. That one would be a 1ghz Nehamiah (spelling?) mine is just a plain 800mhz C3. Your video I believe does hardware mpeg decoding, which mine does not. Should be loads better.
    Tidder
    Try RevFE
      what the hell is all that junk in there?
      Chris Krug
      owner, turbine minivan
      http://www.youtube.com/krugtech
        any second opinions?
          ditch that plexi case. 1 hole and 1 fan? I sense a heat issue, especially the way the hdd is just tossed in there.
            so it's still a worthy buy, but i should take out the parts and install them in a new case?
              i see 2 fans. but i agree some more circulation would be recommended.
              VIA EPIA 533 MHz
              256 MB RAM
              7" Lilliput VGA Touchscreen
              20 gig HD
              Media Engine 2.1.4
              GPS - Earthmate/SA2004
              802.11b Connectivity
                I disagree. I think that that's enough. I have a VCR pc that is roughly the same size, and it has a EPIA 800 in it. It only has one fan. An 80mm in Back. I've ran this thing constantly day and night downloading stuff for about 8 months. No problems at all, even when watching a DivX or XviD movie. I'm sure that it's just fine. Just don't block your intake or exhaust holes.
                Edit: Maybe what I would do is drill a few holes on the ram side of the case. But only if you have heat issues. I really think you'll be ok.
                Tidder
                Try RevFE
                  Originally posted by Tidder
                  Sounds good to me.
                  the video is only mpeg acceleration. only SP and nano has hardware decoding
                  kao
                  CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
                    Well I'll be.
                    Damn I was close though eh?
                    Tidder
                    Try RevFE
                      yes, still a decent buy. Others say it will be ok as is, and they have valid points, but I say, better safe than sorry. Besides, you wouldn't want that hard drive bouncing around while you drive, so you need to attach it somehow. Pickup a real case, then correctly mount the components. You will thank yourself later!
                        I ment case fan. The cpu fan is for the heatsink, and can't really be considered sufficient for moving air through a case.
