possible fix, err, bandaid for usb gps/touchscreen suspend/hibernate woes
  • possible fix, err, bandaid for usb gps/touchscreen suspend/hibernate woes
    My Xenarc often fails to come back from hibernation. If I unplug it and plug it back in, it is fine, or if I restart it is fine, but most of the time it wont come back on its own. I tried several different driver versions, and installing XP SP2 make it come back some of the time, but still not even most of the time.
    I had an idea that maybe I could turn it off before I go into hibernation, and turn it back on when I come back. I was looking into writing a service to do this for me, when I came across this command line utility to do some of the stuff you can do from the device manager. I also found a small script that you can run to catch suspend events. to use this script, save it to a file called SuspendEvents.vbs. the lines that begine with ' are comments and do not do anything. As it is right now the code that works with the devices is commented out, and only the message boxes telling you what is going on show up. You will want to comment the MsgBox lines out after you run it and see how it works.
    Code:
    'this line set up the event monitoring
    Set colMonitoredEvents = GetObject("winmgmts:").ExecNotificationQuery("Select * from Win32_PowerManagementEvent")
    'this gets us a shell so we can run the devcon executable
    'your antivirus software may report a _malicious script error_ due to this line
    Set WshShell = WScript.CreateObject("WScript.Shell")
    'the script loops forever, so you will have to kill it using the task manager
    'if you want to stop it, look for wscript.exe
    Do
    'wait for the next event
    Set strLatestEvent = colMonitoredEvents.NextEvent
    Select Case strLatestEvent.EventType
    case 4
    'put code here to be executed when you go into suspend or hibernate
    MsgBox "Entering suspend."
    'this disables all devices that start with USB\VID_045* (only my usb hub)
    'WshShell.Run "C:\windows\devcon.exe disable USB\VID_045*", 0
    case 10
    'this gives you a notification that you have gone from ac to battery or vice versa
    MsgBox "Power state Changed"
    case 11
    'this event varys from computer to computer in its meaning
    MsgBox "OEMEvent"
    case 7
    'this is run whenever the computer comes back from suspend/hibernate
    'I put in a sleep here to make sure everything else was back up and running
    'before I did anything, it is probably not needed
    'this waits 5000ms (5 seconds) before doing anything
    'WScript.Sleep 5000
    MsgBox "Resuming from suspend."
    'WshShell.Run "C:\windows\devcon.exe enable USB\VID_045*", 0
    case 18
    'I dont know how this is different from the other resume, but they both always happened in my testing
    'WScript.Sleep 5000
    MsgBox "Resume Automatic happened"
    'this restarts the device, but didn't really help me
    'WshShell.Run "C:\windows\devcon.exe restart USB\VID_045*", 0
    End Select
    Loop
    if you download devcon and run it from the command line like:
    devcon status USB*
    it will give you the ids of all the active usb devices on your system. look for the id of the device that you want to do something with. copy that out to the USB\vid_045* in the script above. You can try enabling, disabling, or restaring devices. I also tried removing devices, but I couldn't figure out how to reinstall them without actually plugging it back in.
    what ended up working for me (so far) is disabling the HUB that the touchscreen is plugged in to, then enabling it when I come back from hibernate. I tried restarting when it came back from hibernation, but that didn't work for me. I also tried the same with the TS itself first, but that didn't work either.
    I put a shortcut to this script in my startup folder, so it is run everytime I restart the computer (which hopefully will be less often now). I am not an expert in vbscript, so there may be a better way of doing this, so if anyone has any suggestions, but em up, I wont be hurt
    I also want to see what I can do about finding out the state of the battery and having the script decide to go into hibernation, any idea how I can trigger hibernation from the script?
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
    It looks like I can put this in the above script to automatically go into hibernate after I lose power:
    Code:
    case 10
    Set colBattery = GetObject("winmgmts:\\.\root\cimv2").ExecQuery("Select * from Win32_Battery",,48)
    For Each objItem in colBattery
    If objItem.Availability > 2 Then
    WshShell.Run "C:\windows\poweroff.exe hibernate -warn -warntime 60", 0
    End If
    Exit For
    using the utility that I got here.
    |V1 Virtual Display|
      Looks interesting Might have to use some of the VBS code in AIMEE to detect hibernate/standby
      zPilott, AIMEE already detects going to battery power, and will send your laptop to standby/hibernate etc
      Now I should be able to detect coming BACK from standby/hibernate too And of course there will be options to do certain things on standby/hibernate as well as resume
      Garry
      Co-Developer of A.I.M.E.E
      www.aimee.cc
        I would like to put in a bit more logic in to my power settings. The alarms are nice, but they dont really help if you start at a power level below the alarm. And the timeout doesn't work with some applications running (mainly media players).
        |V1 Virtual Display|
          this is the script I am using now:
          Code:
          Dim lastEventTime
          lastEventTime = 0
          Do
          	case 4
          	case 10
          	  If Timer-lastEventTime > 600 Then
          	        WshShell.Run "C:\windows\poweroff.exe	suspend	-warn	-warntime	30",	0
          	      End	If
          	      Exit For
          	    Next
          	    lastEventTime = Timer
          	 End If
          	case 7
          '	case 18
          '	  WshShell.Run "C:\windows\devcon.exe	enable	USB\VID_045*", 0
          '    lastEventTime = Timer
          	End	Select
          Loop
          anyone know how I can kill a running app in this script (I want to kill poweroff on resume)
          |V1 Virtual Display|
            I am using sendkeys right now to kill the shutdown process, any better suggestions?
            Code:
            Dim lastEventTime
            lastEventTime = 0
            Sub AbortSuspend
              If WshShell.AppActivate("Computer is Shutting Down") Then
                WshShell.SendKeys "{tab}{tab}~"
              End If
            End Sub
            Sub Enable
              AbortSuspend
              WshShell.Run "C:\windows\devcon.exe enable USB\VID_05E*", 0
            End Sub
            Sub Disable
              WshShell.Run "C:\windows\devcon.exe disable USB\VID_05E*", 0
            End Sub
            Sub CheckBatteryStatus
              Dim delta
              delta=  Timer-lastEventTime
              If delta < 0 Then
                delta = (delta + 60*60*24)
              End If
              If delta > 600 Then
                    WshShell.Run "C:\windows\poweroff.exe standby -warn -warntime 30",	0
                  End If
                  Exit For
                Next
              Else
                AbortSuspend
              End If
            End Sub
            Do
              case 4
                Disable
              case 10
                CheckBatteryStatus
              case 7
                Enable
              case 18
                Enable
              End Select
            Loop
            |V1 Virtual Display|
              Can anyone help me with Frodo's Resume function?
              USB\ROOT_HUB\4&16E5A864&0
              Name: USB Root Hub
              Driver is running.
              USB\ROOT_HUB\4&299F5909&0
              Name: USB Root Hub
              Driver is running.
              USB\ROOT_HUB\4&42BF7BF&0
              Name: USB Root Hub
              Driver is running.
              USB\ROOT_HUB20\4&1FE4011C&0
              Name: USB Root Hub
              Driver is running.
              USB\VID_05E3&PID_0701\5&1A3F51A3&0&3
              Name: USB Mass Storage Device
              Driver is running.
              USB\VID_067B&PID_2303\5&2B910C41&0&2
              Name: Prolific USB-to-Serial Comm Port (COM4)
              Driver is running.
              USB\VID_0ACE&PID_1201\5&3063F765&0&2
              Name: (ZD1201)IEEE 802.11b USB Adapter
              Driver is running.
              USB\VID_0EEF&PID_0001\5&2B910C41&0&1
              Name: Touchkit USB Controller for TouchScreen
              Driver is running.
              USBSTOR\CDROM&VEN_MAT****A&PROD_CD-RW__CW-8123&REV_CZ24\6&355F2B22&0
              Name: MAT****A CD-RW CW-8123 USB Device
              Driver is running.
              www.i-hacked.com Hardware hacking articles
                You sure you won't lose your touchscreen by power cycling it? On mine the touch doesn't come back if I power cycle the screen.
                P4 2.4GHz, Intel mobo w/onboard sound & video, 128MB memory, 100GB Seagate Momentus laptop drive, Xenarc 700TSV 7" touchscreen, IRman using Girder, 150W Opus dc/dc psu, Alpine CDA-9835 h/u, MBQuart speakers, Infinity 15" sub, MTX amps.
                  I am not directly power cycling the screen (it turns off and on with the car). This basically unplugs all the devices plugged in to the hub, then plugs them all back in again when the computer comes back from hibernation
                  |V1 Virtual Display|
                    Hi awesome script. I almost have it doing what I want, wheni turn off my car it disables my gps and goes into hibernate. When I start the car it comes out of hibernate just fine but it wont reenable the gps for some reason. Also I think my select statement is wrong because it hibernates once more after the car is on and then it is fine (still no gps on ofcourse ). Oh and i replaced the power line with this:
                    WshShell.Run "rundll32 powrprof.dll,SetSuspendState", 0
                    No need to use a 3rd party program
                    Set colMonitoredEvents = GetObject("winmgmts:").ExecNotificationQuery("Sele ct * from Win32_PowerManagementEvent")
                    Do
                    case 4
                    WshShell.Run "c:\devcon disable USB\Vid_067b*", 0
                    case 10
                    Set colBattery = GetObject("winmgmts:\\.\root\cimv2").ExecQuery("Se lect * from Win32_Battery",,48)
                    WScript.Sleep 5000
                    End If
                    Exit For
                    Next
                    case 7
                    WshShell.Run "c:\devcon enable USB\Vid_067b*", 0
                    End Select
                    Loop
                      Yeah, the external program is kind of overkill, but I had it already on my computer, and it pops up a warning window, which lets me cancel the hibernate. You could also use shutdown.exe
                      The idea for the warning window, and external program is to let me turn off the car, start the hibernation countdown, then turn the car back on, the countdown is stopped, then turn off the power again, but the countdown doesn't go this time (so I can connect to it remotely, or if I know I am only going to have it running from the battery for a little bit).
                      I wan't to make an application out of it, so I can make it a little bit more general.
                      I don't know if your switch is bad, but you might check the If Availability. I had a hard time finding any documentation for what the availibility value is supposed to represent (iirc) and the value there is just what happened to work on my computer.
                      Also, I had some problems with disabling devices directly (worked for some, but not for others) but disabling the hub the device is connected to seemed to work better. are you disabling the GPS or a hub? If you dont have an external hub you might try disabling the root hub.
                      hope that helps.
                      |V1 Virtual Display|
                        I tried disabling the gps itself. I have a work around going on now with a batch file and a button press in frodo so all is good hehe. Just wish these darn manufacturers would make quality drivers that work. grrr
                          My script started barfing recently, and I thought I would replace it, take a look:
                          http://www.mp3car.com/vbulletin/show...810#post614810
                          |V1 Virtual Display|
