What to do for TV tuner?
  • What to do for TV tuner?
    I am getting ready to buy my 6.4" NTSC LCD in the next week or so. I need to figure out some type of TV tuner system. I know I can go out and buy a diversity tuner and antenna for $150, but are there any alternatives? I thought about throwing a VCR in the back and using it's tuner and playing movies in it, but every time you turn the inverter off it resets itself. I don't want to use a tuner card in a computer because I won't always have the computer on, and I wont have the computer for another few months. Does anyone know of any other way to get good reception? I wonder if I could hack an old VCR and use just the tuner and a few buttons and the IR receiver?
    Theoretically yes. Practicaly not really. You might be able to hack it apart enough to get the mechanicals of the tape player out but that may cause the VCR to not work properly because part of its circuitry is missing.
    Catlas
      Thats what I figured. I may just bite the bullet and buy a diversity antenna/tuner. Anyone know where I can get a kit for less than $180?
        its not worth the money
          Maybe where you live it's different, but where I live, there are hardly any broadcast channels and they're all very very very poor quality. ALl the hills, maybe.
          It'd be pretty super rare that I'd find a show on one of the few channels that I want to watch right when I happen to be in my car but stopped. =P
          I'd need a TiVo for my car! ;P
          Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
          Car: 1993 Nissan Maxima, Black Emerald
            Reception is not a problem. The problem is do I want to spend $180 bucks on a tuner or do I want to rig something myself. I may just stick a VCR in the back and be done with it.
              You could wire up the VCR so that it doesn't ever completely lose power. Then it won't reset, and I doubt it draws much power when turned off. If it does though you could spend a few dollars and get a small solar panel that can provide some charge for your battery when the car is off and that will offset some of what the VCR draws. It'd be cheaper than the tuner kit.
                I was thinking about that. But I don't want to do that cause it would be running off a 600 watt inverter that sucks up juice pretty good and has a big old fan that is quite loud. Plus there may be times when I don't use it all day long and I just dont think it would be a good idea. That would be too much hassle to use a solar charger, plus I park in the garage. Good idea though. I wonder if there is a way to use some sort of capacitor to store some energy, just enough to keep the vcr on standby. I beleive the manual says it uses like 3 or 7 watts on standby.
                  You could try to hack your vcr to provide a constant "clock" source ... IE. find the components which handle the settings, etc (volitile ram) .. and provide whatever voltage it runs at (when in standby) ...
                  -J
                  -James-
                  Tech tips and more - http://www.techguys.ca
                  *NIX command for today: rm -rf /bin/laden
                    The average vcr pulls about 20 watts @ 120AC while turned OFF.. All the clock, timer, and other circuitry... BAH!
                    I cheat, I own an empeg.
                    Meskimen's Law: There's never time to do it right, but there's always time to do it over.
                    http://civic.mp3car.com
                      What about switching to an inverter with a built in battery? You can get a 300watt inverter with battery (reburbished) here for $95. There would be a few advantages - the battery would provide power to the VCR to keep it going while the car is off, plus if you wanted to run the computer while the car was off then the inverter battery would power it saving your car battery. Finally, if you ever completely drain the car battery using the computer, the battery powered inverter could give you a jump!
                      When the car is turned on, the car battery will power the inverter and recharge the inverter's battery.
                      Just a thought...
                      Mike.
                        Originally posted by nester:
                        <STRONG>The average vcr pulls about 20 watts @ 120AC while turned OFF.. All the clock, timer, and other circuitry... BAH!</STRONG>
                        actually the manual states <3 watts standby
                          mtmsol, that is a good idea. I actually have a portable battery pike like that. YOu can see it at the bottom right of this pic. It is the blue thing. It has a 300 watt inverter on it. http://www.toyotaoffroad.net/afertig.../cargoarea.JPG
                            these guys had a tuner for 70, I dont think its in the catalogue, call and ask.
                            they are local to me, cust svc sucks, products are good, just make sureyou know exactly what your geting wehn you order, they dont like to do RMAs.
                            http://www.polarisusa.com/
                            Im going by there this afternoon, I will see what they have in stock.
                            Gizmo-
                            Techonlogy on Wheels
                            http://www.hjnetworks.com/car
                              Thanks for the link. I'll check it out. That would be great if you could see what they have in person.
