PCI Video card not working
  • PCI Video card not working
    I just got a new video card to go in my carputer to be i think this is the MB
    and it dosnt work. the computer wont boot up.
    i know the card works as i tested it in my desk top and it works fine.
    is there somthing about PCI that i dont know about that makes this card incompatable with my old mother board?
    i got this card as i need the TV out, Yes i got a composite screen
    Any usefull input is appreciated
    AMD XP 2000+ 512Mb Ram MB:A-7VM400AM-RZ
    Zenarc 700TSV Netgear USB WiFi GPS Opus 150
    Running Win XP, FP, MM
    Requirements:
    Intel® Pentium® 4/III/II/Celeron™, AMD® K6/Duron™/Athlon®/Athlon XP® or compatible with PCI bus 2.2 configuration boards. (3.3V interface only)
    I couldnt get the link to work, but perhaps the board doesnt support the pci 2.2 spec?
    2005 Ford Focus ST
      Make sure the card is seated correctly. One of the bad things with PCI is you can't lock it down as you can with AGP.
      Installed.
      -GPSSecure- - GPS Tracking
        it is seated porperly, i have tested it in to old boards and it wont worik in them, but it does work in my newer desktop.
        any one have any idea when pci 2.2 spec came in?
        i think thats likely to be my problem
          Originally posted by gospeed.racer
          Requirements:
          http://216.239.57.104/search?q=cache...+m758lmr&hl=en
          Installed.
            Did you change the bios to PCI video card before installing the card?
            肚子笑痛了
            S60 Install
              yep, done that
                Looks like to old of a MB then
                肚子笑痛了
                S60 Install
                  Just emailed the place i got it from, see if they have any sugestions.
                  I didnt know that there were different standards for PCI
                  Im running out of options to a TV out signal for my screen
                    I found out the same thing with an agp card, went to plug it into a newer mobo, and....grunt, push, tug, yank, wouldnt fit! Seems the old card wont physically fit the new agp connector. Grrr.
                    To bad they didnt do that with the pci express, it would make it painfully obvious that it wanst meant to work if it wont plug in.
                    2005 Ford Focus ST
