How do I reset the BIOS?
  • How do I reset the BIOS?
    I got a V1000 Mobo and i was messing with the power setting in the bios and now the damn motherboard wont turn on. I hooked it up in my house like my desktop and still wont turn on.
    Ive searched and seen people say to reset the bios but no one has said HOW to do it.
    My Carputer Project
    usually a little jumper next to cmos battery. If all else fails, pull your cmos battery out for a while.
    Tidder
    Try RevFE
    I Wish I could ban people
      As Tiddler said: Next to your battery is a jumper for it.
      I know nothing about the VIA motherboards but I think the jumper is usually red.
      I assume you know how to use the jumper?
      Installed.
      -GPSSecure- - GPS Tracking
        i pulled the battery out and put it back in, nothing.
        And no, i dont know about jumpers. I mean i know what they do, but i dont know what setting to put them too.
        I see the red jumper. there are 3 pins it can go on=.
        My Carputer Project
          Make sure you unplug all power to the mobo before you pull the battery. Some mobo's keep power to the cmos thru your PS.
          Tidder
          Try RevFE
            Unplug your computers power and move the jumper over 1 pin. Let is sit there for a bit and then move it back.
            Installed.
              As far as the red jumper goes, you want to move it to jumper the middle pin and the pin that's not jumpered right now. DO NOT power up the system this way. Leave the jumper for a few seconds, then put it back where it was.
              Tidder
              Try RevFE
                tried the jumper thing...nothing
                My Carputer Project
                  Did you fry your MB?
                  Did you pull everything that isn't needed out of your mb?
                  Installed.
                    i dont think i fried it. it was working fine. then i shut it down thru windows.
                    everything is unhooked.
                    My Carputer Project
                      Try different PS?
                      Tidder
                      Try RevFE
                        i did. i just bought a new PS and tried that, nothing. tried hooking it up to my desktops PS...nothing. Tried hooking it up to OPUS150, nothing.
                        I tested the little battery and it has 2.9v
                        i read somewhere you need to remove the battery for like 30 min
                        My Carputer Project
                          You did move the jumper back right? It won't turn on if it is in the reset position. What all do you have plugged into the mb right now?
                          Installed.
                            Well, give it a try. You sure you have your power button on the right pins? (I know, but sometimes it's the simple answers)
                            Tidder
                            Try RevFE
                              the power supply cord coming from my power supply and an IDE cable going to my hard drive.
                              tidder. I have no power button. the MOBO boots when i switch the PS button to ON.
                              My Carputer Project
