Ding Dong my hard drive is gone :(
  • Ding Dong my hard drive is gone :(
    So yesterday I spent a few hours cutting a larger hole in my subwoofers box because my 10 inch died and I bought a 12 inch Kenwood. Got everything installed and working. Drove to work and on the way I was testing out my sub (make sure it was giving me enough thump ) and my carputer reset. I let it boot back up and as soon as windows booted it reset again. This time I got a disk read error. I brought it in today and ran like 20 differant diagnostic programs and tried to repair it. No luck. I finally decided to just try and format it. That worked and I loaded my music library back on. I put the hard drive back into my carputer and tried loading windows on it. It is able to copy all the files over but it won't boot off the drive (it just goes black). I tried this with several Windows CDs and either got the same results or worse.
    Sounds like it is time to get another hard drive unless any of you have further suggestions.
    Installed.
    -GPSSecure- - GPS Tracking
    what exactly did you run to try and fix it? you use any of the manufacturers utilities?
    might be time to invest in a laptop drive
      Originally posted by rusty
      SNIP
      Whatever...
      Brady,
      What drive was it, Make/model/size?
      TruckinMP3
      Read the FAQ!
        I ran Norton Disk Doctor, the Seagate utitilities and some other programs off of Hirem's boot cd.
        It is a Seagate 120GB hd. 3.5"
        I was finally able to get Windows loaded on it. It is acting semi unstable... I am going to play with it a bit longer and hope all my problems go away
        Installed.
          hahahahahah, i couldnt stop laughing when i saw the title, but yeah that sucks good to hear its kinda working tho
          Signature: [==||========] 20% complete
            Originally posted by TruckinMP3
            Whatever...
            lol - i use a desktop hdd as well... but if it goes then i think i'll probably buy a laptop hdd to replace it.
            the seagate utilitys are good - they've resuced a disk for me before which was looking dodgy.
            glad it's okay
              So u put windows on the drive in another system then ur carpc? WindowsXP and 2000 uses ur hardware like motherboard and CPU to boot, if you place a harddrive with windows in another setup it will never boot (unless ur very lucky, or you have the same setup)
              05155'30"N 0434'31"E
                No I didn't install Windows with differant hardware.
                Perhaps the Seagate utility did do something. It had found a bunch of bad sectors that it couldn't repair but I have yet to run into any problems for awhile. I have now reinstall everything and it is up and running. Restarted it a bunch and it doesn't freeze up the computer anymore.
                Installed.
                  I have moved boot drives from one PC to another with diferent hardware (win2k) it worked just fine for me. It takes time the first boot, has to find all the new hardware... even MB level stuff like the IDE bus and PCI bridge.
                  TruckinMP3
                  Read the FAQ!
                    hmm it never seemed to worked at my but it is possible ya..
                    Maybe you should try a low level format.. You waranty will be voided probably but its worth the try..
                      Why using Lower lever format will void the warranty? I have use it couple time.
                      2006 Camry
                      Compaq Laptop
                      Holux GPS Iguidance 3.0
                      7" Xenarc Touch Screen
                      Carnetix 1900 Power Supplied, Wireless b/g
                        Not sure really, i know for a fact that maxtor doesnt matter if you low level format but seagate disagrees the use of lowlevelformats.. Why, i havent got a clue.. I look it up for ya
                          It doesn't void the warranty to do a low level format.
                          So it is official. I put the hard drive back into my car after I thought it was working again but after an hour or two it did the same thing. This time I am not going to take the whole day troubleshooting and reloading everything. It is gone.
                          :'( <---------- Me crying.
                          Installed.
                            idk about this but maybe u put the drive vertically??? when the actuator jumpped it might have gave sum negative magnetism or positive jolts and mucked it up??? this is the thing im still wonder of how i should put my hdd in too.............but im going for horizontal...im not really sure but u should rma that thing...btw i have been using wd drives for a while they served me good. if u ever replace ur drive dont go for ibm death stars, they dont call those death stars for no reasons lol!!!
                              As favored by most forum members I had mine mounted vertically (supposedly so the platters don't crash into each other). I actually just proccessed the RMA!! Wahoo, it was one month from the warranty expiration.
                              Installed.
