Sub Woofers in Car
  • Sub Woofers in Car
    I just need some advice on putting subs in my car along with the computer. Is this in any harm or danger to the hard drive and if so how can i prevent damage?
    Wes_Cyde
    Amazingly enough, most people who have put them near each other haven't complained much. I am going to assert that this will PROBABLY shorten the life of any HDD that has to deal with the vibration. I'm not saying it will fail right away, but you may not get your $150 worth if it dies in only a year or two.
    I don't konw if there's a really decent answer to this right now. For constand vibration, I'd guess a set of gromets would dampen it really well, but that reduces the HDD's heat dissipation. Always a trade-off...
    -M
    Public PGP key available on http://keyserver.pgp.com/pks/lookup?...@MyRealBox.com
      Wes_Cyde:
      i really don't think it should be much of a concern. i haven't heard of any harddrive crashes due to the HD being next to subs. now of course it may shorten the lifespan a bit... now if it was me, i would not put the computer directly behind your subs - just to be safe. i would space the two at least a foot away from each other.
      ...it's your call, man.
      g00d-Luck!
      //dj
        Hey all, I have my pc right next to my 2 12 inchers for about 6 months now and had any problems at all with the hd. Just keep rockin your trunks with that subs, no prob at all
          My main concern would be the magnets, since they can wreak havoc on computers, especially the hard drives. If you have them close at all, you should magnetically shield them.
            You'r right, I should, but...
              I've got two HDs in an old desktop case that is standing vertically on it's side. It's directly behind the back seat in the trunk with my subwoofer box right up against it (two 10"). So when you open the trunk you only see the sub-box and can't see the PC. To access the PC, you gotta fold down the backseat.
              Anyway, I've been doing that for 8 months and have had no adverse effects from vibration or from the magnets. And since I'm using some old free hard drives that I don't care about, I've done absolutely no special mounting. They can crash and it'd be cake to replace the system with a new drive (which I would take more care in mounting). All of my MP3s are backed up at home, so I don't worry about losing those.
              -nickel
