HYBRID RS-232 Controlled 16-Relay Driver with 5 or 10-Amp Relays
  • HYBRID RS-232 Controlled 16-Relay Driver with 5 or 10-Amp Relays
    Hello everyone,
    I have been lurking around for a while and was wondering if anyone has seen this.
    http://www.controlanything.com/Merch..._Code=IOADR165
    I used the and did not see any information in the forums. Has anyone used one of these? If so, what was your impression of the build quality and company. They appear to be rather pricy, but also is loaded with options.
    BeaverWise
    Have purchased my monitor (Xenarc) and MB (via MII 10000) but am still working through the design phase.
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
    Anyone???
      I think I've seen this board mentioned before, you might search for something about AC controls. It looks pretty awesome, but like you said, pretty pricey.
      I would love to have one of those, but I'm looking at one of these, since it fits into my budget.
      There are also some USB boards like this.
      Do you really need that many inputs/outputs?
      2000 Subaru OBS
      Dell P3 @ 900 Mhz
      7" Lilliput TS w/DigitalWW in-dash mount
      80GB External HD
      I am Zero Bitrate....
        I agree they look like great boards but they are dam pricey!
        the one you just mentioned http://www.mpja.com/productview.asp?product=6074+KT
        i do believe that wizard pc has already coded an application to allow use of this baord for AC controls, it has unfortuantly only 8 outputs and no inputs whatsoever.
        the phidgets boards are great boards but again fairly pricey for what they are
        im currently waiting for RICKY327 here on the forums to complete hes design then we add full support into AIMEE once this is complete. hes board promises to have outputs that you are not limited to a specific current rating or a relay amnd inpust that can be configered to read analouge or digital values
        and best off all cheap!
        Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
        www.aimee.cc
          Cool, I will be watching RICKY327s project. I was planning on purchasing this card this week. Do you have a guesstamat as to when a user level product will be available under RICKY327's project? I checked out the thread referenced, but it doesn't specificly say. Any ideas?
