VIA Support for pc-3200 on M1 or MII
  • VIA Support for pc-3200 on M1 or MII
    does anyone know if you can use PC 3200 ram on the VIA boards made to use 2700??? I realize that you would still be running at 266 mhz bus speed, but my interest is to get an M board for now and then to later buy one of the new boards but not have to replace the RAM.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    yes, all the newer ram can run at the slower speeds, they are all backwards compatible.
    I am running 3200 in my M10000 just cos it was cheaper than the 2700!
      thanks
      thanks for the reply, that is what i fuggured but wanted someone to say, Yep I have done it, no problems. Thanks
      My Install
      Software:
      CFiG v1
      CarShell
      StopWatch
