Need help with automatic dimmer control
  • Need help with automatic dimmer control
    Based on some conditions, either external to the CarPc or internal (some events), I like to be able to control 12v light source. Say, I have a condition or trigger that occurs at 0%, 25%, 50%, 75% and 100% - based on this input; I would like to control the light as if someone is turning the knob on a dimmer.
    So, if the condition is 0%; no light, at 25%, the light is 25% bright, and so on.
    I have 2 questions; 1) how to do that using the CarPc or a stand alone controller. 2) I would like to do the same, except this time, I have a strip of LEDs, say 100 LEDs, again, if the condition is at 0%, then no LED is lit, at 50%, half the LEDs are lit, you get the idea.
    I really need to do this badly; any help or links would be appreciated.
    i think the electronics component for a dimmer is a TRIAC. you can control current with voltages or some such thing. its been a while since my electronics days.
    also x10 ( has some dimming switches, i dunno if thats what you want. thats AC stuff mostly but you may be able to rig it.
    VIA EPIA 533 MHz
    256 MB RAM
    7" Lilliput VGA Touchscreen
    20 gig HD
    Media Engine 2.1.4
    GPS - Earthmate/SA2004
    802.11b Connectivity
      The LEDs really depend on the number of segments you wish then to dim in. For instance, it is MUCH easier to break the 100 LEDs into 4 groups of 25 than it is to break them into 100 groups of 1. Check out the link below... they have some ideas.
      2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
        Couldn't find any thing related, nothing that could be interfaced to carpc or controller.
          I dont get it really... You want to make a light source for in your car with like 100 LED's? And then you want to control those LEDs with a dimmerpack?
          05155'30"N 0434'31"E
            May be this:
            Just arrange your lights in group of 4 and there you go.
            Car pc integration with ease
            Car mediacenter
