Extra Extra Extra long IDE cables
  • Extra Extra Extra long IDE cables
    i've seen pictures of installs that have cd-roms in the headlining and i was wondering where you get IDE cables long enough to get all the way into the boot?
    I want to use a swanky remote control i've found thats got a reciever meant for floppy drive bays. i've got a nice little cubby hole in the dash to put it in, but i'd need a really long cable.
    Any ideas???
    Any ideas???
    Hmmmm... ever heard about USB?? :-)
    The max. lenght of IDE-cables is 90cm.
    SkyFlyer
      They make 15 Feet long IDE cables, it was posted once or twice, do a quick searcyh, u'll find it.
      2011 Nissan Frontier SL
      AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
      OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
        Any ideas???
        The IDE specification is for cables a maximum of 18 inches long. You can get cables longer than that. I'd think 24 inches is the practical usable limit for IDE. Anything longer is going to decrease performance (at best) or not work at all (at worst).
        For a longer run, convert to USB of firewire.
        If you'd have used the , you'd know this already.
        How about the Wiki?
          It 's not said that because the receiver uses a floppy bay that it will use ide or the 34p floppy connector. It'll probably be usb or serial...
          Joa
          List of front-ends/usefull apps
          XTroniC | XTroniC Direct
            This has worked well for me - and they're very reasonably priced. I just hope they continue to keep these items stocked.
            http://www.compgeeks.com/details.asp...2IDE-N&cat=HDD
            I've personally built a 6+ foot ide cable out of shielded CAT5, and can tell you from experience that it's not a worthwhile venture. The IDE bus was not designed to deal with the EMI associated with long cabling. Put this in the EMI rich environment of a car / carpc and the problem only gets uglier.
            '01 Chevy Xtreme Stepside (pics)
            FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
            WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
            350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
              Well to shut all of you naysayers up.
              My 6 foot IDE cable works perfectly. And for you who pointed out USB as an alternative. In a sense you are correct (that it is an alternative).Firewire is a much better alternative (if you have that capability)
                Yeah, you and your evile doings with long IDE cables....
                It's still outside the official spec.
                Glad it works for ya, REALLY. But for someone wanting to hook one up, I wouldn't count on having a 6-foot (or longer) IDE cable and expecting it to be trouble-free.
                Also, having your IDE shielded behind all sorts of lead helps, doesn't it?
                How about the Wiki?
                  I have 2 high quality 24" IDE cables which cause CRC errors whenever I use them with my high end Abit motherboards. Sometimes the systems won't even boot correctly, and this happens with more than just 1 hd or motherboard, so let's just say you got lucky, there is a reason that the specs say not to go that long (nor would I trust it anyways).
                    the only really good way to do this is with cat5 table.. I did it for my long ide run till a dumbass friend decided to pull it up and rip the cable. I didn't want to go back and build a new one.
                    I'd just run usb2 and get a converter at the ide end.
                    '98 Explorer Sport
                    80% done
                      Okay guys lets clear some things up.
                      First off my IDE cable is 40 pin 80 conductor 2 connector (i would try hooking up more than one drive)
                      Furthermore I am only using this as an extension for my slimline CD drive. I would never consider using this for a hard disk drive... ever.
                      I too when setting up my computer went the USB route and had problems so i eventually sucome to the extended IDE cable idea. Having another device (Fire wire or USB-->IDE) just is another power hungry mouth to feed.
                      So obviously you see the benifits of using IDE over USB or Firewire. And heck if it works who gives a crap that it is beyond the narrow brained people that created it's spec.
                      BTW I have seen people with 15 footers that work fine
                        15 foot!!!!! oh are we talking about cables???
                        on a more serious note, did you use any shielding or any other extra precautions on your long IDEs?
                          haha
                          absolutly no shielding and this IDE cable must be passing every power and signal cable within close proximity in my car
                            Wrap tin foil around it wrap that in electical tape, and connect one wire to teh tin foil and the car chassis. Home made shielding. Worked for me.
                            RevFE
                            My Shop
                              Ok.. how about some resources for this long cables?
                              Live mp3Car Facebook Chat
