Super TV/FM Tuner desperate help needed.
  • Super TV/FM Tuner desperate help needed.
    Basically,
    I wanted a cheap input card for my rearview camera.
    So I bought one of these
    http://cgi.ebay.com/ws/eBayISAPI.dll...ayphotohosting
    It was cheap, and it was all over ebay so I figured with all those sales there had to be some support for it.
    I knew that Radiator had Conexant 8x8 support.
    This one was a conexant 878a Fusion chipset.
    Does anyone else have this card?
    Has anyone got it to work with Radiator?
    Ive tried the generic 8x8 drivers but none seem to work.
    Any help would be appreciated. I really dont want to have to buy another card. This one works great with its own software and drivers.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Noone else has this card?
      To test if it works, have a search for Dscaler. It's a TV program that uses it's own drivers not those supplied (you don't need to install new drivers either) or Axife FM lite to test the radio.
      I have a WinTV PVR that uses the Connexant 878, and that has all sorts of troubles with getting it to work with Radiator, but Axife lite works fine.
      4x4 in a turbo stylee.
        yea, Ive tried them both. My main problem is switching sources. If I open the TV app it came with, and select the TV app, close the program, any app I use I get that same source. All the apps I use to select my camera, its distorted with BTwincap drivers. I dont want to have to buy another card.
          Hmm, thats odd. Because I found that DScaler worked even without the Wintv drivers installed, and picked up sources fine.
          And Axife worked better than the Hauppauge drivers.
            I have that exact same tv card. I havent tried it with a rearview cam though, so im afraid i cant help. I can say the card works perfect for normal TV though
            http://www.digital-car.co.uk
              Take a look at this TV/Radio card. The Radio has RDS !
              http://productsen.terratec.net/modul...rder=0&thold=0
                I have a Leadtek version of that with the same (i think?) Conexant chipset. It works fine except the interface is kinda crappy and not very stable.
                I am looking for alternative software right now that has a more touchscreen friendly interface.
                  I cant get any other app to work with it, eventried different drivers, which also will not work.
                    Taken from the site "(Not available in the UK)"
