inverter buzzing
  • inverter buzzing
    I just bought a cd player for my truck and now my computer audio is hooked into an front aux jack, the only problem is the inverter buzzing is a lot louder than it was when I had a tape deck. How can I fix this?
    ground loop isolator? If so what do those do?
    A ground loop isolator doesn't fix the problem, but at least eliminates the symptoms. I assume you have tried grounding the inverter and power supply case?
      should i ground the inverter and the computer? both?
        yes definatly
          but ground them both at the same spot
